We 259 e cam
Old Mar 13, 2018 | 10:04 PM
Mackdyna's Avatar
Mackdyna
Default We 259 e cam
just purchased a 103 kit for my 96 and it comes with the se 259e cam. Anyone have any info on it? The compression will be a 10:5:1. Wondering if I should swap it out for a s&s easy start or keep the 259. Thanks
Old Mar 14, 2018 | 05:03 AM
Slingshot383's Avatar
Slingshot383
I have that cam in my Stage IV 103 Ultra Limited. It gets up and goes, no complaints.
Old Mar 14, 2018 | 05:37 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Not a low end cam.......
Old Mar 14, 2018 | 09:45 AM
Mackdyna's Avatar
Mackdyna
With the 10:5:1 compression I was reading it helps with the low end
Old Mar 14, 2018 | 11:07 AM
hrdtail78's Avatar
hrdtail78
Is it really 10.5:1 or is that HD's advertised numbers? They usually come in a couple of points lower than advertised. Even with 10.5 and a 47 closing. It won't be a bottom end cam.
If wanting EZ starts. I'd suggest the Rocket 574. With a 38 closing. It will work better at 10.3-10.5:1.
Old Mar 14, 2018 | 11:08 AM
rhuff's Avatar
rhuff
I'd think that cam would want more than 10.5 to make it shine. It's still going to be soft on the bottom at 10.5.
I had an Andrews 67 (which was pretty much a twin to the SE 257, which is pretty similar to the 259). My compression was at 10.8 and I still thought the 67 was soft down low. I'd look at more compression and a tuner that can tune it, or get a different cam.
Old Mar 14, 2018 | 11:32 AM
Mackdyna's Avatar
Mackdyna
It’s the stage 3 upgrade and it states 10:5:1 and the kit comes with that cam
Old Mar 14, 2018 | 12:30 PM
Mackdyna's Avatar
Mackdyna
Old Mar 14, 2018 | 08:44 PM
Ed Ramberger's Avatar
Ed Ramberger
257's turn on a little later and will be a little softer on the bottom.
259 is virtually identical to the 251 - look up the specs.
In the EFI super tuner, the maps even list them as 251/259E as interchangeable when performing a cam selection. I have a 103 with 251 and it's got more than enough grunt fight from the get go. It's a good cam for a heavy bike.
Old Mar 15, 2018 | 07:16 PM
Mackdyna's Avatar
Mackdyna
Also have been looking into the Woods 777 cam. Any other options
brawner11
Engine Mechanical Topics
Nov 13, 2018 10:54 PM
rdc401
Milwaukee Eight (M8)
Nov 5, 2018 08:55 PM
ringer1969
2014-2024 Touring Models
Apr 30, 2018 06:43 AM
Patti Buffington
Apr 15, 2015 02:18 PM
natural gasser
Exhaust System Topics
Feb 19, 2011 04:58 PM
