Raising cylinder compression
Old Apr 20, 2018 | 02:07 PM
cgptv's Avatar
cgptv
Default Raising cylinder compression
In a Se 110, how much would have to be removed to get the compression from 10:4 to 1 and increase it to 10:8 to 1 or slightly better. Thanks.
Old Apr 20, 2018 | 02:13 PM
djl's Avatar
djl
About .020" should do it.
Old Apr 20, 2018 | 09:11 PM
Mattbastard's Avatar
Mattbastard
Cometic gaskets might get you there, depending on what your current thickness is.
Old Apr 21, 2018 | 12:16 PM
martinj's Avatar
martinj
Assuming a stock 0.045" gasket, a 0.030" gasket would get the OP to right at 10.7:1. Not quite there. Personally, a 0.010" cleanup cut with the thinner gasket is how I would go.
Old Apr 22, 2018 | 12:20 PM
Mattbastard
All my stock head gaskets have been .060", but that's on Evo's and Sportsters. Not sure on TC.
Old Apr 22, 2018 | 05:41 PM
martinj's Avatar
martinj
Stock head gaskets are 0.045" on Twin Cams. Just to confirm, I checked a head gasket recently pulled from my bike. 0.046".
Old Apr 23, 2018 | 06:04 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Best to clean/prep, then cc the chambers.
Then the guesswork will be in the rear view mirror.
Scott
Old Apr 23, 2018 | 06:46 AM
prodrag1320's Avatar
prodrag1320
Scott
100% agree`d.if you don't have the facilities to cc mill the heads to do the job properly,use a shop that can
Old Apr 24, 2018 | 11:34 AM
cgptv's Avatar
cgptv
I had them done but they never recorded the numbers. My ccp is 195 warm. We are planning to remove the heads and installing a .030 gasket in place of the factory one. At that time we will record the size. With that stated is my ccp going to be to high for pump gas. I do not want to go above 210.
Old Apr 24, 2018 | 01:08 PM
Hillsidecycle.com
Sponsor
We don't like going above 200 here.
Scott
