Oil pressure
Old Jun 28, 2018 | 08:56 AM
rsking45's Avatar
rsking45
Default Oil pressure
So im up way to early this morning,looking at post made here, ended up at S&S website watching videos about their cam plate and oil pump,from there to Zippers performance. I know they all want my $$$$
So now it has me wondering about weather or not I need to upgrade my cam plate and oil pump,or if Id benefit from installing a LMR oil pressure spring with Baisley bypass plunger in my 2015 flhxs. Im sure it wont hurt but do I really need to worry about it right now? 19000 miles on the bike
What is your oil pressure when the motor is up to temp? At idle and when riding
At cold idle oil pressure is 35 psi, once up to temp idle it’s between 17-20 psi,while riding it stayed 34-35 psi.
Iv been chasing a top end tick left side of motor, that occurs between 2000-2500 rpms.
Below or above the rpm range the tick inst there. I tried the rocker lockers and no change
Thanks All
Old Jun 28, 2018 | 01:41 PM
Mike Lawless's Avatar
Mike Lawless
These things just don't need the kind of oil pressure people are used to seeing in automotive engines. About the only thing that relies on oil pressure is the lifters. Unless they bleed off oil so bad the oil pump can't keep up, they are probably not the cause of your tick.
At that narrow of an rpm range, I'd be thinking "harmonic resonance". That particualr vibration frequency that causes something to rattle or buzz. Maybe a heat shield, footpeg/floorboard? Seems I'm always chasing that kind of stuff. Fix one, and another starts making noise.
Old Jun 28, 2018 | 02:46 PM
djl's Avatar
djl
Oil pressures are fine; no need for the LMR spring or the Axtell bypass chingadera; focus on finding the "tick". Impossible to diagnose via the forum, a video might help though. Has the tick always been there or is it new? Adjustable pushrods? What lifters? Is your "left" side the primary side?
Also check for the harmonic stuff as Lawless suggested; look in the area where you believe the noise comes from a for things that could possibly make contact. The motor is still moving around a bit in that rpm range.
Old Jun 28, 2018 | 07:41 PM
rsking45's Avatar
rsking45
Ill have to take a video sometime. I don’t remember if the tic was there befor the cam install or not. It’s just a light tic coming from the top left side of front cylinder between 2000-2500 rpm. I pretty sure I pin pointed the tic coming from the rocker erea using my Stethoscope. I did Andrews 48 S&S adj pushrods with there tappets. I set the p/r up to .140 and the tic is still there.
Over this coming winter I’ll tear it down and find what is making the tic.I was more concerned about having correct oil pressure than the tic.
Thanks all
Old Jun 28, 2018 | 10:25 PM
ROCKOUT Rocker Products
Sponsor
Try Spectro 25-60 dino oil... nothing better when it comes to noise.
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Jun 28, 2018 | 10:50 PM
bad tappets's Avatar
bad tappets
Are you sure you're not hearing injector tick? Run the bike at 2000-2500 and give it just a bit of throttle; tick go away? Probably injector tick, it's normal.
Old Jun 29, 2018 | 08:27 PM
rsking45's Avatar
rsking45
Yep that’s what happens. I didn’t know a injector would make that ticking noise. I’ll have to get my stethoscope out and listen to the injectors.
Thanks for the info
Old Jul 31, 2018 | 11:58 AM
Guntoter's Avatar
Guntoter
Mine would make a little noise around 2500 rpm or so but it’s gone now since I had some head work done with new valve springs, retainers and keepers. No noise at all at any rpm.
ScottinAZ
Engine Mechanical Topics
13
Jan 29, 2019 07:18 AM
cajun1957a
Aug 20, 2018 09:56 AM
SJ_Phil
Jul 31, 2018 05:22 PM
FastHoss
Jul 23, 2017 05:13 PM
RBWIDE
Oct 30, 2008 07:44 AM
