clearanced rocker boxes?
Old Jul 5, 2018 | 01:59 PM
JeffJA's Avatar
JeffJA
Default clearanced rocker boxes?
so, i have an 03 Road king classic i got used, the guy i got it from bought it used from a dealer and doesn't know much about it, it came with a stage 1 intake and and exhaust, ive always "thought" it had a cam by the idle, but am unsure, so while i had the rocker boxes apart to install rockout inserts, i noticed someone grinded or added clearance the lower rocker boxes around where the valve spring goes, is this something that is done for "bigger" lift cams?
i have pics but am unable to load them for some reason.
Old Jul 5, 2018 | 05:10 PM
prodrag1320's Avatar
prodrag1320
its done for bigger springs,which are installed for bigger cams.so it would be my guess youve got other than stock cams
Old Jul 5, 2018 | 05:23 PM
JeffJA's Avatar
JeffJA
thanks!
im trying to tune it with my powervision, but i kinda don't know where to start not knowing whats in there for cams without pulling them.
Old Jul 6, 2018 | 10:36 AM
djl's Avatar
djl
Pull the cam chest cover; the cam is probably identified with a stamp on the end of the shaft.
Old Jul 6, 2018 | 02:23 PM
JeffJA's Avatar
JeffJA
i did when i check the tensioners, the one end of the cam i could see didn't say anything, the other is behind the cam gear.
Mototech
Engine Mechanical Topics
19
Nov 30, 2017 02:55 PM
grubsie
EVO
23
Nov 16, 2017 10:30 AM
SummitRK
Sep 30, 2014 09:57 PM
texashillcountry
EVO
Jan 28, 2014 09:00 PM
gipper
Sep 30, 2013 12:21 PM
