Flush engine after piston galling?
Old Jun 23, 2020 | 05:15 PM
roussfam's Avatar
roussfam
Originally Posted by Z
S & S provided new pistons and cylinders for free which gives some validity to the idea that they were defective somehow.
​​​​​​Mechanic made sure oil pan was clear but I don't think he actually flushed.
Broke in new set very deliberately and now have about 15k miles on the build.
My friend had an S&S 110 kit, same thing, new parts covered
Old Jun 24, 2020 | 10:10 AM
Z's Avatar
Z
If my issue was somehow faulty parts coming out of S & S, I'm surprised as hell to see it still happening and I wonder how often it does.
Between the cost of hotel stays, truck rental, shop diagnostics where I broke down, repair back home, and lost vacation days, this issue cost me a few grand. It cost S & S nothing more than one set of jugs and pistons.
Obviously, my faith in S & S is low enough now that I'll not likely be buying their brand any more.
Old Jun 24, 2020 | 10:54 AM
Jackie Paper's Avatar
Jackie Paper
There is a plug in top of cam plate. I would also remove check valve. Run oll back thru from oil pressure sending unit.
Drop oil pan off transmission. Replace the two oil injectors if it's a TC
Be sure that piston to cylinder clearance is correct measured properly. Even without properly calibrated tools, if you use a inside mike and then use the outside mike, you will know clearance.
I just rebuilt a 1.6 Vtec Honda. All pistons looked like that. One of the cylinders had zero clearance. They also forgot to put the pilot bearing in the crank (actually flywheel in this case). That tore off a clutch friction disk) and did a number on the transmission input shaft.
Rashmeet
Apr 12, 2019 11:47 AM
brian4.2
Oct 20, 2018 08:54 AM
13RoadKing
Oil Archive (no new posts)
Feb 1, 2017 06:03 PM
the4thgearkid
Apr 16, 2011 01:53 PM
gyrnorth
Apr 4, 2007 06:00 PM
