Long Block Program
Old Aug 2, 2018 | 03:04 AM
Kenney's Avatar
Kenney
Just my on keeping an older bike. (see my post on this thread) I have always leaned toward reliability over anything else. My nightmare is being broke down on some back road 300 miles from home, at the mercy of tow truck drivers and Dealers. (You can add your own scenarios and horror stories). This can happen with new bikes and old. So I keep to regular maintenance, replacing warn parts (if in drought it gets replaced. Yes this is sometimes expensive but compared to pice of mind its worth it to me) Wheel bearings, swing arm bushings, drive belt, shocks, steering head bushings, cables, etc. All things that can get overlooked until they break
As far as making the decision to replace a motor or get another used bike depends on too many questions that only the individual can make.
My situation was the Dealer found my motor (98" Stage 3 98/107) problems while in for a base gasket replacement. They had been weeping for the last year and getting worse. So once they started with the teardown it was "It could go another 50 ft. or 500 miles but its a wonder the it runs at all". The farther into the motor they got the more they found. it started with a badly warn rocker arm cracked valve seal, cam due to or because of the rocker arm, scored cylinders, and the final blow was the crank. (know problem with the twin cam motors) Yes i saw all of this damage and agreed with the Dealer. The repairs would have been more than the new motor $$ and going to the S&S 111 or the 124 would have required even more changes and $$$ (larger throttle body, air cleaner, new clutch.) As I had the bike setup the way I wanted it with all of the add-on chrome accessories and stereo it was a no brainer to replace the motor with the HD Long Block. (103" and cam Stage 2 making +100/100) So I have a USED 2005 NEW Ultra 50K miles and starting to count miles again with a new motor.
KenK
Old Aug 4, 2018 | 07:02 AM
marcodarq's Avatar
marcodarq
Get in touch with Kirby at VeeTwin Racing. See what his price would be to remanfacture what you already own.
m
Old Aug 4, 2018 | 07:21 AM
Notgrownup's Avatar
Notgrownup
At 92000 I bought a 103HO out of a 14 Street Glide with only 10000 miles on it for $2000..swapped it out ,sold my 96 for $1000 paid a local indy to swap it out due to my Arthritis...
I love the bike now, stronger than before with 26h cams...while I had it open I replaced the belt, swing arm bearings , bushings, inner primary seal, then I did a Barnett clutch, new spring and a Baker compensator...I also had the dealer activate the Automatic compression releases....
i have a 07 that potentially can last the rest of my life...
Not saying the HD longblock program is crap but for a lot less you can get so more...
Old Aug 4, 2018 | 07:40 AM
Kingglide549's Avatar
Kingglide549
7000 !
That's ridiculous .
i think a whole S&S ischeaperr then that.
bighatlaw
Touring Parts
Nov 8, 2015 10:54 AM
beaureed445
Nov 23, 2009 09:17 PM
russl179
Mar 27, 2009 07:01 AM
badinfluence63
Nov 1, 2008 08:03 AM
lsc86
Exhaust System Topics
Apr 7, 2008 04:41 PM
