Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Yep, got mine from Heartland. Got a puller tool and an installation tool for the same price as just a puller from most other vendors. It did not come with instructions but I emailed Heartland and they emailed me instructions right away. Both tools worked great and were easy to use. Heartland has some good stuff for reasonable prices.
__________________________________________________ ____ For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
I got the Heartland TC88, 96, 103, 110 tool and the Heartland Evo tool all for less than a Harley or Jim's TC88 tool. Just got them last week. The Evo tool came with a new Torrington bearing.
Wanna rent out the Twin Cam tool? I'm doing the cam plate upgrade on my 01 FXDXT and that is the last piece of the puzzle to make it happen.
