Lifter noise
Old Sep 6, 2018 | 10:09 PM
  #31
PreachermanCSC's Avatar
PreachermanCSC
6th Gear
Bore looks good, but previous owner put adjustable lifters, SE 260 cams, V n H exhaust, Thunderbolt and stuff, I bought with 13,000......buth left stock lifters......I figured the lifters were changed.....
Old Sep 7, 2018 | 05:09 AM
  #32
Jackie Paper's Avatar
Jackie Paper
Community Influencer
How can the wear area on the inner race of the lifter roller be wider then the cam lobe? What does the cam lobe look like?
Old Sep 7, 2018 | 06:10 AM
  #33
Ben221's Avatar
Ben221
Find all th pieces or most of them? Is the cam okay?
How long did it run after this blew apart? I assume a very brief time so the bits did not get to far.
Old Sep 7, 2018 | 07:17 AM
  #34
Jackie Paper
With that worn area on the inner race of the roller, it appears after the roller broke, someone adjusted the pushrod to work with it . What is strange is it appears wider then most cam profiles.
Big parts usually stay in cam case galley.
Old Sep 7, 2018 | 09:17 AM
  #35
PreachermanCSC
6th Gear
I road about 7 miles to home. It rattled at take off and squeaking. Changed Compensator but of course still knock.
Old Sep 7, 2018 | 09:20 AM
  #36
PreachermanCSC
6th Gear
Cam is scored...need cam , pump, cam plate, bearing , seals.
Old Sep 7, 2018 | 09:24 AM
  #37
PreachermanCSC
6th Gear
Really concerned, we ride long trips, recently returned from 15,000 mile ride..... prudent to do crank and mains... draining oil shortly and see it I can cut oil filter....old racing method.
Old Sep 7, 2018 | 09:26 AM
  #38
Ben221's Avatar
Ben221
Ouch. Sorry to hear and it’s a crappy reason to get a few upgraded parts.
FLAMED96
May 7, 2010 09:41 PM
Night Pig
Exhaust System Topics
Oct 14, 2009 06:01 PM
jjb
Jun 13, 2009 06:59 AM
bobdion
May 3, 2008 08:02 AM
murf1
EVO
14
Apr 7, 2008 07:24 PM
