Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
So yes, I will try to rebuild my motor, but if I have to buy a replacement mill,
will any TC88 motor from those years (99 - 05) that aren't softail motors (i.e. dyna WG or touring models) bolt right up to my FXDX frame, trans and primary, and work without any mods?
Please and thanks.
Please and thanks.
Yes they will one possible exception. You might need to change the ignition module to 1 that doesn't need a cam sensor. Don't forget that 06 bagger motor will also work. 06 dynas? No...
Interesting.
The 06 bagger motor is a 96" no?
But didn't I hear lots of warnings to stay away from the 2006 models?
