Engine build recommendations
Old Sep 15, 2018 | 05:31 PM
allthefineprint@gmail.com's Avatar
Default Engine build recommendations
i have a 04 road king, first owner took it 24k miles in 4 years, second owner took it less than 1k in 10 years. I got the bike this spring and did everything to it - all new fluids, scavenged the hell out of the engine oil - drained the gas - bled the burned brake fluid out and replaced the tires. It’s a great bike, but I’m looking for more.
I ride typically around town and up and down some very steep hills. I’m more focused on getting good hp/tq from 0-60 than I am from 60-100, although I do get out on the open road half the time. I ride only solo.
What at would you recommend for cams, 98 kit, heads, springs - anything. I plan to do everything aside from crack the case. I’ve got some ideas, but I’d like to use forum vendor supporters with solid information from seasoned engine builders.
Ive got not problems doing the work and have all the tools from previous projects.
Thanks!
Old Sep 15, 2018 | 09:32 PM
Max Headflow's Avatar
Max Headflow
Since you are having the heads done. talk to the guy doing the heads. Hillside, prodrag and WFOLarry can all set you up.
Old Sep 16, 2018 | 07:33 AM
prodrag1320's Avatar
prodrag1320
a nice,mild reliable build that's worked great is 98",mild touring headwork,S&S .570 or Andrews 54 cams with compression set @ 10.2-1.good HP/TQ from 2200-5500
Old Sep 17, 2018 | 06:19 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Another torque-specific touring combination that our clients like is this;
Our HMM Stage II Heads
Our HMM 98" Big Bore Kit
Andrews 26 cams
9.7 compression
Comes up on the torque very quickly, and carries it out.
No frills straightforward combination that just works.
Scott
bhollis
Oct 4, 2009 07:39 PM
cmashark
Sep 20, 2009 09:56 AM
jrhd1
Exhaust System Topics
Sep 3, 2008 06:50 PM
Bluzmn59
Aug 8, 2007 09:37 AM
broke joker
May 4, 2006 11:55 AM
