New Engine Help Going go 95
Old Oct 4, 2009 | 05:32 PM
bhollis's Avatar
bhollis
Default New Engine Help Going go 95
Guys, I'm working on putting a combination together but I need to know what you guys think. I have a 06 road glide. I'm going with a 95 inch but I got a great deal on a set of ported and polished SE 110 heads. Will these heads make good power with the 95"? Thanks!
Old Oct 4, 2009 | 05:36 PM
UltraKla$$ic's Avatar
UltraKla$$ic
May I suggest listing what your game plan is about getting to 95", then these guys could "build" on your suggestion(pun intended) listing pro's and con's. Listen to the ones you trust.
Old Oct 4, 2009 | 05:51 PM
bhollis's Avatar
bhollis
Well, I have forged S&S flat top pistons, 625G Gear Drive Cams. I'm looking for about 100 hp but it needs to have good torque. I'm just concerned b/c I don't know much about the heads. I would like to know what you guys think.
Old Oct 4, 2009 | 07:18 PM
gunnert's Avatar
gunnert
You won't find much low end or mid-range torque with the 625 cams. The 625s were made for the 116" Hot Setup Kit. A much better cam would be S&S 570. The 570 works really well with compression close to 10.5:1. I can't speak to the S/E heads. A mild porting job of your stock heads works well for the 570s. Tuned properly you'll be close to 100 HP and over 100 lbft torque.
Old Oct 4, 2009 | 07:39 PM
Bigredone's Avatar
Bigredone
I went with Headquarters setup using the HQ039 cam. Just over 100 HP and pulls like crazy.
cike
Engine Mechanical Topics
Mar 6, 2014 12:00 PM
matt816
Exhaust System Topics
Aug 16, 2010 07:42 PM
Sheldon
Jan 1, 2009 09:03 PM
LawrenceFromTorrance
14
Jun 2, 2008 07:16 AM
bdaug50
Aug 31, 2007 09:47 AM
