Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Hi, I have a 2017 SGS with about 15000 miles. Bike is stock except for ventilator air cleaner and harley tuner. I took a trip recently and during a couple of inital start ups I heard a very large noise almost like a hammer striking the top of the motor. After a few seconds it stopped. Bike ran well the entire trip but the noise was very concerning. Once home, I changed the oil and all was fine until yesterday when I started the bike after seeing a movie. Again, very loud noise like a hammer hitting the heads. Noise disapated after about 10-15 seconds. This only occurs sporatically as most start ups are normal. All three times the bike has been outside and not in the garage. Any chance my open air filter is drawing in moisture although filter has been on over a year?
I've read some past postings in regards to this but no one really pinpointed the issue. I have made an appointment with dealer who says it could be the pump, but if that were so would it run well after a few seconds?
Has anyone had this concern and found out why? This noise never occured until about 13000 miles and is awful sounding on start up. I have trouble accepting this is normal and not damaging the motor? Suggestions??
Are you referring to a startup clunk these V twins are famous for? If so, sounds like your battery cables are a little loose. This makes for a poor connection letting the motor kickback since the starter is weak. Check cables and also might as well remove the battery and charge it 24 hours and have it load tested.
Like MAX says, also, a lifter bleeding down will make you think you have a rod knock and it is going to blow up. Whenever I have to turn motor a lot working on one with no oil in it, I never start it up with owner around the first time.
As already said, sounds like a lifter bleeding off, and the valve lash is being heard via the pushrod ball end, dancing in the rocker arm cup, echoing in the rocker covers.
We'd suggest to replacing with a top quality lifter, such as an S&S, and with an adjustable pusrod, load the lifter to .140".
Replace the inner cam bearings at the same time to prevent headache further down the road.
Scott
2017 bike, you still under warranty??? Might be time for a trip to the dealership. All good advice given, but it all will cast you money. Maybe this one can be handled by them and cost them money. Good luck.
