Start up noise
Old Sep 6, 2011 | 12:44 PM
JONNIEROCK's Avatar
JONNIEROCK
Default Start up noise
Does anyone else have (or had) this problem. I've got an 2009 ultra Classic. After riding awhile and getting the motor up to temp. I find that after letting it set for 15 minutes or so, and starting it, it makes a real loud clattering noise, like lifter noise. The dealer put in new lifters at 15,000 miles and again at 23,000. it has 2,000 miles on these lifters, and still makes noise on restart up, which leads me to believe the problem is somewhere else. Anyone have any ideas.
Thanks in advance Jonnierock
Old Sep 6, 2011 | 12:50 PM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
If the noise goes away after a few seconds, it's just a lifter bleeding down. I hate to ask... but what oil are you running?
Old Sep 6, 2011 | 12:51 PM
Cowboy Rob's Avatar
Cowboy Rob
Big Kahuna HDF Member
Damn that sucks,if a bike goes through that many lifters,something is WRONG!
Old Sep 6, 2011 | 12:53 PM
shooter5074
Dealer probably keeps putting in those crappy 99b lifters.
I have one on my 2011 that bleeds down if the motor shuts off with tension on the spring on that particular valve.
Old Sep 6, 2011 | 12:58 PM
Burch753's Avatar
Burch753
Stab in the dark here, but it is the compensator missing as all of ours do.... Mine will be getting the SE version very soon.
Old Sep 6, 2011 | 08:19 PM
enzoultra's Avatar
enzoultra
6th Gear
burch 753. ( Hope I got that right, can't remember one minute to the next). You are correct. Its the oem compensator sprocket. The SE comp is the fix. Changed two this past week-end. One in a 2008, the other in a 2007. Totally fixed loud banging noise. Enzo
Old Sep 6, 2011 | 08:22 PM
spiker's Avatar
spiker
Did mine this morning,problem fixed.
Old Sep 6, 2011 | 08:38 PM
Teardrop's Avatar
Teardrop
Was the noise like the OP described?
Old Sep 6, 2011 | 08:58 PM
spiker's Avatar
spiker
It was a bad chatter and then a loud pop when starting when hot.
Old Sep 6, 2011 | 09:45 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
You need the screaming eagle compensator to replace the piece of crap stock one. My buddy had this issue, replaced his started twice to no avail. Then he added the S/E compensator and the problem has never happened again. His bike is an 09 UC with about 40K miles on it.
Drew
