Idle Problems
Old 10-15-2018, 10:03 PM
VTwin-Goodies's Avatar
VTwin-Goodies
VTwin-Goodies is offline
Sponsor
Received 1,935 Likes on 1,919 Posts
__________________
Old 10-15-2018, 10:14 PM
Lou'sUltra's Avatar
Lou'sUltra
Lou'sUltra is offline
Received 1,273 Likes on 1,264 Posts
Welcome from Ohio
Old 10-15-2018, 10:32 PM
lmar's Avatar
lmar
lmar is offline
Received 2,073 Likes on 2,055 Posts
Old 10-16-2018, 01:40 AM
sloufoot's Avatar
sloufoot
sloufoot is offline
Moderator
Received 4,082 Likes on 3,484 Posts
Old 10-16-2018, 09:32 AM
djl's Avatar
djl
djl is offline
Received 2,031 Likes on 1,499 Posts
The OP should keep his post up here; this is the "Engine Mechanical Topics" spot. '00 model EFI was MM and, as I understand, lacking in some areas.
First thing you need to do is verify that the DC voltage is reading .275 with throttle plates completely closed, IAC motor disconnected and cold/hot idle screws backed. Setting the TPS to .275 is a PITA; the TPS is very sensitive and it will take some trial and error to get it set. Once set; the DC voltage for cold/hot idle has to be set; this is easier. Rather than go through the steps, check out the video link; hope this helps.
Old 10-16-2018, 07:06 PM
Ed Ramberger's Avatar
Ed Ramberger
Ed Ramberger is offline
https://www.youtube.com/watch?v=bY6Pw8WpSfc
Actually .275v was a misptint carryover from EVO MM. A sweet spot for TC MM is .195. This was never publicly corrected or retracted. In many TC MMs, .275 sets them very very rich at idle.
Old 10-16-2018, 09:47 PM
critter85's Avatar
critter85
critter85 is offline
Received 2,497 Likes on 2,475 Posts
Welcome to the Forum
Old 10-17-2018, 08:14 AM
djl's Avatar
djl
djl is offline
Good to know!
rab474
10-09-2011 02:12 PM
hawc929
Welcome Area Only
04-26-2011 05:54 PM
chucktowndcroz
Welcome Area Only
13
10-02-2010 03:42 PM
brettnbama
12-21-2008 08:39 AM
kjc625
01-27-2008 11:44 PM
Quick Reply: Idle Problems
