Idle Problems
Old Oct 15, 2018 | 10:03 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Old Oct 15, 2018 | 10:14 PM
Lou'sUltra's Avatar
Lou'sUltra
Welcome from Ohio
Old Oct 15, 2018 | 10:32 PM
lmar's Avatar
lmar
Old Oct 16, 2018 | 01:40 AM
sloufoot's Avatar
sloufoot
Old Oct 16, 2018 | 09:32 AM
djl's Avatar
djl
The OP should keep his post up here; this is the "Engine Mechanical Topics" spot. '00 model EFI was MM and, as I understand, lacking in some areas.
First thing you need to do is verify that the DC voltage is reading .275 with throttle plates completely closed, IAC motor disconnected and cold/hot idle screws backed. Setting the TPS to .275 is a PITA; the TPS is very sensitive and it will take some trial and error to get it set. Once set; the DC voltage for cold/hot idle has to be set; this is easier. Rather than go through the steps, check out the video link; hope this helps.
Old Oct 16, 2018 | 07:06 PM
Ed Ramberger's Avatar
Ed Ramberger
https://www.youtube.com/watch?v=bY6Pw8WpSfc
Actually .275v was a misptint carryover from EVO MM. A sweet spot for TC MM is .195. This was never publicly corrected or retracted. In many TC MMs, .275 sets them very very rich at idle.
Old Oct 16, 2018 | 09:47 PM
critter85's Avatar
critter85
Welcome to the Forum
Old Oct 17, 2018 | 08:14 AM
djl's Avatar
djl
Good to know!
rab474
Oct 9, 2011 02:12 PM
hawc929
Welcome Area Only
Apr 26, 2011 05:54 PM
chucktowndcroz
Welcome Area Only
13
Oct 2, 2010 03:42 PM
brettnbama
Dec 21, 2008 08:39 AM
kjc625
Jan 27, 2008 11:44 PM
