do i reuse my push rods?
Old Nov 15, 2018 | 10:36 PM
allthefineprint@gmail.com's Avatar
Default do i reuse my push rods?
i'm going to do an entire camchest rebuild with my cams this winter - i'm also going to do 100ci jugs and roller rockers. as i'm going to have the top end open, is it still in my best interest to use new adjustable pushrods, or can i reuse the stock rods from the 88 twin cam.
thanks.
Old Nov 15, 2018 | 10:45 PM
Scarydog's Avatar
Scarydog
You should be able to use the stock rods. Make sure you lable which one goes where, from what I know they may have different lengths. It will make it more work to get into the cam chest again if you need to later.
Old Nov 16, 2018 | 01:15 AM
vonh12's Avatar
vonh12
I'd replace with adjustable pushrods myself.
Old Nov 16, 2018 | 06:24 AM
Fat11Lo's Avatar
Fat11Lo
First question: Do the new cams have the same base circle as the old ones? If yes then it is possible, however adjustable push rods will give precise control over lifter preload.
Old Nov 16, 2018 | 08:45 AM
djl's Avatar
djl
Check base circle as Fat11Lo has suggested but the OP must also take head gasket thickness and whether or not heads will be decked and do the math to determine the new valve train stack up height and how much preload the OEM push rods will set on the lifters. If preload works out to be between .125" - .145", nothing wrong with using the OEM pushrods. But if lifter preload is less than .125", adjustable push rods might be a better choice. If OEM push rods are retained and there is some valve train noise, the OP can always cut the OEM push rods out and install adjustables.
As for roller rockers, unless the OP is installing cams with lift higher than .600", roller rockers are a waste of money; not necessary, expensive and they will make more noise than OEM rockers. I make that statement from personal experience, not something I read on the internet. I run .610' lift cams with OEM rockers on one bike and .595" lift cams in another with S&S roller rockers; guess which one is quieter than the OEM chain drive setup?
Paul32730
Exhaust System Topics
Apr 29, 2026 11:37 AM
evhid1
Engine Mechanical Topics
14
Jul 22, 2017 06:27 PM
Stl.glider
Jan 4, 2013 08:45 AM
Molarman
Dec 26, 2012 05:32 PM
Chula
Mar 26, 2009 09:40 PM
