Adj Pushrods? Yes or No
Old Mar 26, 2009 | 10:22 AM
Chula's Avatar
Chula
Default Adj Pushrods? Yes or No
I am having a 103" II kit installed. Should I have adjustable pushrods installed? Yes or No - Why or Why not?
Old Mar 26, 2009 | 10:29 AM
stro1965's Avatar
stro1965
Unless you plan on cam swaps in the future...why? I used adjustables but only because I didn't pull the heads, you will, so I'd stick with stock rods, one less point of potential failure.
Old Mar 26, 2009 | 10:32 AM
El Loco's Avatar
El Loco
stick with stock even if you plan to swap cams in future then you can cut them .
Old Mar 26, 2009 | 10:35 AM
BadPiggy's Avatar
BadPiggy
A 1-piece (solid) pushrod will always be better than an adjustable.
Stick with stocks unless you put a hi-lift cam in.
Old Mar 26, 2009 | 10:40 AM
Uncle Peepers's Avatar
Uncle Peepers
My vote is no. I've used adjustables for a long time, but after I pulled the heads this winter, I returned to stock. IMHO, adjustables are a pain to adjust unless you have three good hands, and you're always wondering if you got them right. I can almost remove the rocker box covers and rocker arms in order to drop in stock rods as I can adjust the adjustables. I'm sure a lot of people think the adjustables are easier, but with my dexterity, they're not.
Old Mar 26, 2009 | 11:12 AM
dawg's Avatar
dawg
+1 this is the only correct answer as you never stated the cam you are using. That or perfect fit rods.
Old Mar 26, 2009 | 11:47 AM
Chula's Avatar
Chula
Thanks for the help. I am having the SE 255 cam installed, so it will be covered under warranty. So in what circumstances does one use adjustable pushrods?
Old Mar 26, 2009 | 12:08 PM
iclick's Avatar
iclick
I agree and although I didn't pull the heads for my cam-only project (SE255's) I decided to keep the stock pushrods. It saved $135 or so but increased the hassle, as the rocker covers and plates both have bolts that are very hard to access. The added time involved may have been 2-3 hours. It isn't rocket science but is very aggravating. For the $135 savings I would probably do the same thing again, but like you said if you plan on going into the cam chest often, like for changing cams repeatedly, I would probably buy adjustables. OTOH I also agree with Uncle Peepers that adjusting pushrods can be very tedious even with small hands like I have.
The downside to adjustables is that they tend to be larger diameter than stock and can sometimes touch the tubes, often causing noise that is sometimes hard to track down. They sometimes are not perfectly straight and I've even seen some move the tubes as they touch them. They can also come loose, although my old Evo had adjustables and only came loose once in >100k miles when I failed to tighten the jam nut properly. They are also almost always heavier, which although may not be an important factor isn't a positive characteristic either.
Old Mar 26, 2009 | 12:10 PM
Scorpion07's Avatar
Scorpion07
Funny you ask. Just read this this morning! Very informative.
https://www.hdforums.com/forum/touri...ge-report.html
Old Mar 26, 2009 | 12:14 PM
iclick's Avatar
iclick
So the SE255's will keep the factory warranty intact? The SE catalog states "for race application only" for all their cams, including the SE255's, so I'm surprised that they would consider it different than any of the others. It is the stock cam in the CVO bikes, of course.
