Loud ticking and pulled the rocker box off, upper retainer is chewed up
Old Jan 5, 2019 | 07:59 AM
  #31
Kingglide549's Avatar
Kingglide549
Nah
A OS speed will bend a valve, not whack the crap out of the top of the retainer.
JMO
Old Jan 5, 2019 | 08:33 AM
  #32
Ed Ramberger's Avatar
Ed Ramberger
Originally Posted by Kingglide549
Nah
JMO
I agree but I like the thought process.
Old Jan 5, 2019 | 12:41 PM
  #33
Kingglide549
Someones guess will be right........LOL
Old Jan 5, 2019 | 01:21 PM
  #34
Max Headflow's Avatar
Max Headflow
Originally Posted by Hillsidecycle.com
Looks like the valve is pulling thru the collar.
Valve lock issue, or bubble-gum soft collar.
Scott
That would be my guess. Aluminum valve collar? Something got caught between the collar and rocker? .. PIcs of the rocker arm?
Old Jan 5, 2019 | 04:38 PM
  #35
Ed Ramberger
So little info and pics - so much fun we are all having. No matter what, I still think the pics make it look like the boxes were not clearanced Clarence.
Old Jan 5, 2019 | 07:47 PM
  #36
Max Headflow
Well Clarence, I'd go for something caught between the rocker and spring collar, assuming everything else is stock. Valve springs and collars aren't. Generally from what I've seen, when the lower rocker covers are not clearanced, the outside edge of the collar hits. The damage appears on the inner part of the collar. I would also guess that it ran for a while to "develop" a tick. From that I see of the valve springs they are smaller OD than the higher performance springs and the collars/springs are not stock 88. 96. 103.
Old Jan 5, 2019 | 07:56 PM
  #37
Ed Ramberger
LOL Max. But seriously - even if it isn't the cause because it could be anything at this point - doesn't it look like the boxes weren’t clearanced? I realize there are not obvious marks but it does look too close for comfort in the pics. I've seen them tick and visually you could baaaaaarely tell they hit but they were close in proximity.
Old Jan 5, 2019 | 09:07 PM
  #38
Max Headflow
Well Ed, I don't think that marks were caused by a clearance issue. From what I've seen the later model lower rockers have better clearance than the earlier TC rocker box lowers. While the springs are straight wound and not beehives, they seem smaller OD than most aftermarket springs. They don't look any/much bigger than stock early springs.
Old Jan 5, 2019 | 09:33 PM
  #39
Ed Ramberger
I'm not talking about the marks - just am looking at the distance between collar and box. It's just a visual observation. You could be 100% and they are stock size and the pic just makes it look close. I did think about a soft collar like Scott suggested, but that's pretty rare. I was initially I was thinking interference of collar to box, but it would have to be big. Incorrect keepers - you might be on there. I was just having fun with it as it's really just a guessing game - none of us are there to physically inspect it, and unless it is truly a soft component, I am 10000% certain neither you, Scott nor myself would build something that would hit. But the OP hasn't even posted the component PNs.
I am onboard that the rocker arm was into the collar. It had to with it that low in the collar. Oh well - Just trying to have a good time in the rarely given the full story internet diagnostic game!
Old Jan 15, 2019 | 03:24 PM
  #40
Zanthamos's Avatar
Zanthamos
What does the rocker arm look like, if you have adjustable PR's and they are adjusted too short could cause beating rather than smooth operation as well, especially if the other valves that are setup identically are looking OK.
memphisharley
Engine Mechanical Topics
May 19, 2019 11:00 AM
JeffJA
Jun 24, 2018 08:13 PM
Zim
Powdercoat & Paint
May 22, 2014 03:04 PM
Beedub109r
Exhaust System Topics
Nov 25, 2013 05:44 PM
Hawaii-Five-Jo
Dec 9, 2012 12:23 PM
