Is this timing off?
Old Jan 5, 2019 | 04:18 AM
Cascade's Avatar
Cascade
Default Is this timing off?
I can't get my head around this. Is the timing off, or is is just chain slack/stretch?
The dots do not line up 100%
Old Jan 5, 2019 | 06:06 AM
Lambda's Avatar
Lambda
It's just fine, the sprockets are rotated sigthly, that's why you see that the dots doesn't match 100%, if you rotate the engine slowly you will come to a point where they match
Old Jan 5, 2019 | 07:40 AM
Hoginedgewood's Avatar
Hoginedgewood
You're there
Old Jan 5, 2019 | 08:42 AM
bustert's Avatar
bustert
sure, wear and stretch can have this effect. also not following install protocol. it does make a diff which direction of travel you use, you want the slack on one side. when the tensioner extends, it will roll the chain to a degree so the marks do not align.
Old Jan 5, 2019 | 01:27 PM
Max Headflow's Avatar
Max Headflow
If you look at it closely, The chain ain't stretched enough..
Old Jan 6, 2019 | 01:18 AM
Cascade's Avatar
Cascade
So we’re good here? Thanks alot
Shadowbennie
2014-2024 Touring Models
21
Jan 4, 2019 11:57 AM
cbacon1788
May 3, 2018 10:17 AM
Lockeshill
Mar 27, 2017 10:11 PM
Johneb48
Mar 20, 2007 02:43 PM
HD7585
Jan 14, 2007 12:11 PM
