fuel tank cross over line
Old Feb 2, 2019 | 12:52 PM
matt_m_72's Avatar
matt_m_72
Default fuel tank cross over line
2002 electra glide, injected, how much pressure runs in the tank cross over line?
Old Feb 2, 2019 | 01:01 PM
QC's Avatar
QC
None. Just what gravity provides.
Old Feb 2, 2019 | 01:04 PM
matt_m_72's Avatar
matt_m_72
So I can use any clamps when I put the tank back on?
Old Feb 2, 2019 | 01:05 PM
QC's Avatar
QC
Yes, worm screw clamps are what I use.
Old Feb 4, 2019 | 10:01 AM
djl's Avatar
djl
Incorporate a quick disconnect in the cross over; next tank removal will be so much easier.
Old Feb 4, 2019 | 12:05 PM
Mattbastard's Avatar
Mattbastard
Yup, you can get the Motion Pro device that seals off both ends for like $15
Old Feb 4, 2019 | 01:39 PM
Architect's Avatar
Architect
This, on every bike I have after the first time the tank has come off. Next time, a tank can be removed without draining the fuel, makes things much, much easier.
Old Feb 4, 2019 | 09:52 PM
QC's Avatar
QC
Part number for this one? I had one of their plastic ones that eventually broke.
Old Feb 5, 2019 | 09:53 AM
djl's Avatar
djl
The one in the photo is no longer available; got it from Herko, an HTT member but he no longer sells them and I believe because they are not made any more. I recently set up a cross over on my '05 FXSTD and used Goodridge fittings; a bit pricey but, as you have experienced with plastic, the plated brass/bronze fittings will not leak or break. I got mine from Summit Racing but you can check around and maybe find these or another cheaper; dunno. The metal quick disconnect fuel line fittings are hard to find; I guess the cheaper plastic fittings are more in demand.
Old Feb 7, 2019 | 08:26 AM
QC's Avatar
QC
Thanks.
