TC88 inner bearing fail
Old Feb 7, 2019 | 03:11 PM
jenius308's Avatar
jenius308
6th Gear
Default TC88 inner bearing fail
I was in the process of doing the cam chain tensioner upgrade kit for TC88. Apparently I didn't have the bearing puller tool in very well and when pulling the inner cam bearing out the bearing fell apart inside the cam chest. There was a clump of a few of the needles in the bearing hole i pulled out with a magnet. I have found 20 of the needles so far, but I think there should be a couple more. I'm not sure just how many there should be. I made a little magnet tool to try and reach down the bearing hole but it's too tight. I can't seem to get anything in that hole to fish out any more of the pieces out. I'm pretty terrified of what ya'll are going to say to do next. Any clever ideas to retrieve the remaining pieces??
Old Feb 7, 2019 | 03:32 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
No real terror in splitting the crankcase.
You will know at that point, and be able to sleep easy.
Scott
Old Feb 7, 2019 | 06:14 PM
Ed Ramberger's Avatar
Ed Ramberger
Because you are hitting the flywheel. I believe INA had 23 bearings. Only way to look down into the case to see is to pull a cylinder or split the case.
Old Feb 7, 2019 | 08:03 PM
jenius308's Avatar
jenius308
6th Gear
Scott
i definetly want to be sleeping easy. The added expense is the scary part.
Old Feb 7, 2019 | 08:06 PM
jenius308's Avatar
jenius308
6th Gear
Thanks for the number count on the bearings. I’ll probably split the case. Better safe than sorry
Old Feb 7, 2019 | 08:09 PM
Ed Ramberger
To 100% verify just get someone here to count or get a junk one from the dealer. You have to remove the jugs to split cases so I would look down in at that point and compare all parts retrieved to an assembled bearing. I don't have any laying around or I would count for you. Gaskets are cheap - don't worry. Also, I have several sets so we can get you the good guy deal - we will get you through this.
Old Feb 8, 2019 | 05:21 AM
prodrag1320's Avatar
prodrag1320
if all rollers cant be found,drain the lower end end & flush it with some kerosene.that should get the rollers by the drain
Old Feb 8, 2019 | 06:40 AM
Mattbastard's Avatar
Mattbastard
pull the crankcase drain plug and use a strong magnet on the outside of the case to work any possible remaining pieces towards the drain hole.
worth a shot as opposed to splitting the cases.
Old Feb 8, 2019 | 08:58 AM
jenius308's Avatar
jenius308
6th Gear
Good options y’all. Thanks a ton! I’ll give it all a go and see what turns up.
Old Nov 20, 2021 | 03:41 AM
Damien 604 - 05fxdc's Avatar
Damien 604 - 05fxdc
2nd Gear
Great Idea
