oil leaking after oil pump change
Old Feb 8, 2019 | 09:18 PM
dynamac's Avatar
dynamac
Default oil leaking after oil pump change
I have a 2003 Low Rider. Just changed out the cams, chest and oil pump. Adjusted everything and started up, test ride around the block, come back and oil is coming out of the bottom of the all 4 pushrod covers and also from the oil filter were it mounts against the adapter. Everything is tight. I probably have to go back into the camchest but any ideas what I should look for. Its a new feuling camchest and oil pump. She never ran so quiet before.
Old Feb 8, 2019 | 09:21 PM
Kingglide549's Avatar
Kingglide549
Sounds as if you have a breather problem? (timed venting)
Or oil pump hose mixed up?
Old Feb 9, 2019 | 04:22 PM
djl's Avatar
djl
Did you replace the cam plate? Could be the pressure relief valve stuck in the closed position. When installing a new cam plate I always pull the pressure relief piston from the bore, polish it up a bit and make sure it moves freely in the bore.
Old Feb 10, 2019 | 11:28 AM
Max Headflow's Avatar
Max Headflow
If you have oil leaking from the filter, then as djl says, you likely have a stuck relief valve.. It's also likely the reason why the lifters are so quiet..
tootal
Engine Mechanical Topics
18
Apr 9, 2015 09:41 AM
f4dennis
25
May 27, 2014 10:10 AM
rockstar
Oil Archive (no new posts)
Aug 8, 2013 09:42 PM
fireaxxe
Aug 24, 2011 10:44 AM
Jesse_the_kid
May 15, 2009 07:26 AM
