Comp difference front to rear
Old Mar 28, 2019 | 02:43 PM
tc66nova's Avatar
tc66nova
Default Comp difference front to rear
I put woods TW 7H cams in my 2012 FLHTCU with the heads milled .025 and Cometic .030 head gaskets. Now I can hear a distinct difference in the exhaust from side to side (Rinehart true duals). So I did a comp test and have 165 in the front cylinder and 125 in the rear. This is with the engine warm and the throttle held wide open (does it even really open if the bike is not running?) Any ideas? It has Power Vision with a tune from Fuelmoto that is not really for my combo but it was as close as they have. I also have the Target Tune and wide band O2 sensors. The bike runs strong except for a very noticeable miss or surge with a popping in the exhaust from 2700-3000 rpm that I can only feel if I try to cruise at that RPM. If I roll on it, it runs right thru that range with no issues.
Old Mar 28, 2019 | 03:14 PM
djl's Avatar
djl
A leak down test should follow to see where the lost compression is going. If the leak down results are good, cam timing would explain the lost compression. Being off one tooth will allow the motor to start and run (not as well as it should) but will show the compression variance you are seeing.
Old Mar 28, 2019 | 04:25 PM
Max Headflow's Avatar
Max Headflow
One of the things to note is that if the cam timing is off, it would have to be off on both inner and outer cam chains assuming that the 165 is what you are expecting. I'd oil the rear cylinder and and see if it comes up. Your popping on the 3K is more than likely tune. If you ran it for some time with a bad tune, you likely hurt the rear cylinder.
Old Mar 28, 2019 | 05:05 PM
tc66nova's Avatar
tc66nova
Default Thanks
Thanks for the replies, l will leak down test it in the A.M. I have only put about 40 miles on this since doing the work and Fuelmoto says that I need to run 2 tanks of fuel thru it and let the Target tune do it’s thing before they even want to look at data. I am suspecting cam timing off but I thought that I was pretty careful on that. I have built high performance sbc for years and even a few shovel heads, but everyone can make mistakes.
Old Mar 28, 2019 | 08:00 PM
Max Headflow
I would say if you changed cams or set them up on a SBC, you'd get it right. The manual makes it pretty simple. It's not like you are trying to set the cam timing on a worn out Honda CB450..
Old Mar 29, 2019 | 02:40 PM
tc66nova's Avatar
tc66nova
Found it! When I hooked up my leak down tester I hear a distinct hiss from under the rocker box = ACR???
Old Mar 31, 2019 | 06:36 PM
1 2 many's Avatar
1 2 many
Default Acr
could be. on my Pv I could disable the acrs. On a tbw bike the throttle will not open full throttle while cranking.
Jim Anderson
EVO
Sep 23, 2024 09:57 PM
Z
Engine Mechanical Topics
50
Sep 16, 2018 11:11 PM
Jeckel
Aug 16, 2016 03:24 PM
brawner11
Apr 7, 2014 07:43 PM
jhnmflr
Exhaust System Topics
18
Oct 16, 2009 07:23 PM
