Evo top end rebuild ?
Old Oct 12, 2009 | 05:38 PM
jhnmflr's Avatar
jhnmflr
Default Evo top end rebuild ?
I should start by saying my bike ( 87 softail ) was sarting to do some smoking while at idle after a while riding . Did compression test front cylinder120 , rear 125 . Did a leak down test and front cylinder 40 % intake and rear was 20 % exhaust losses . Tore it down to take a look . I could see after head removal the valves were seating horribly . Front cylinder has some white kinda of build up on the side of chamber on head . Pulled pistons and found some markings on skirts and front cylinder piston has a lot of build up ( oil ? )
yanked cam , there was pitting on lobes and pulled lifters , same pitting . So I want to go with andrews ev3 cam , new lifters , manley 10 over pistons ( stock compression 8:5/1). manley valves and spring kit . Heads will be done and a 3 angle valve job with the bottom cut being radiused into cumbustion chamber . Also polishing and porting on the heads . Already have a cran high 4 single fire with coil and adjustable push rods , Vance and hine sbig radius 2 / 1 exhaust . Any thoughts on a different set up or should this be good ?
Old Oct 13, 2009 | 06:12 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
The Andrews 3 cam is a good one, as is the 27, and the Wood 6.
The only other thing that I would reccomend would be to surface the heads, -.060", as any/all of those grinds responds VERY well to at least that.
Scott
Old Oct 13, 2009 | 06:46 AM
jhnmflr's Avatar
jhnmflr
When I bring the heads in to the machine shop I will talk to him about that . I couldn't see any clearance problems , piston , valve or could there be ?
Old Oct 13, 2009 | 07:31 AM
prodrag1320's Avatar
prodrag1320
Default valves
none of the cams you selected have a real high TDC lift,so shouldnt be a prob,BUT ALWAYS SHOULD BE CHECKED!!
kirby
vee twin racing
Old Oct 13, 2009 | 03:26 PM
Hillsidecycle.com
Sponsor
Check twice, cut once.
Scott
Old Oct 14, 2009 | 03:34 PM
jhnmflr's Avatar
jhnmflr
If I go 0.060 on the heads what kind of compression can I expect or how can I calculate that ?
Old Oct 14, 2009 | 03:52 PM
prodrag1320
should put you a little over 9.0-1,but you`ll have to cc them to get a real #.
kirby
vee twin racing
Old Oct 14, 2009 | 03:59 PM
jhnmflr's Avatar
jhnmflr
Thanx Kirby , found a calculator and without knowing cc's if I want 9.5-1 I would have to go .090 . Seems a lot to me . What do you think .
Old Oct 14, 2009 | 04:06 PM
prodrag1320
dont really want to go .090,ide go with new 9.5-1 pistons,cc them now and see how far youd need to go to get 9.5-1
-.060 with a .030 h. gasket might get you in the ball park,78.9cc`s would be 9.5-1
kirby
vee twin racing
Old Oct 14, 2009 | 06:51 PM
jhnmflr's Avatar
jhnmflr
i really appreciate the feedback . Checked into 9.5's but wiseco doesnt make em . Only 10- 1 . To high without compression releases . I have the old style saterter and heard there are issues with starting .
