overheating after pulling primary
Old Apr 8, 2019 | 08:30 PM
brc0703's Avatar
brc0703
really? cuz the oiling hole is in a horrible location
Old Apr 8, 2019 | 08:50 PM
Max Headflow's Avatar
Max Headflow
That because the hole is not needed.. If you want to be **** about it, get the SnS bearing retainer plate, It has a deflector that directs the oil to the gears. Still it's not needed.
Old Apr 10, 2019 | 03:05 AM
brc0703's Avatar
brc0703
not being **** just dont want to find the hard way about mismatching parts together.. so enlighten me why is the hole there but not needed? do gears not need lube like chains do?
Old Apr 10, 2019 | 09:52 AM
Max Headflow
The gear survive just fine on splash. BTW, that cam plate looks shot. Looks like a bunch of crap when through the pump.
Old Apr 10, 2019 | 04:32 PM
HarleyGTP's Avatar
HarleyGTP
Wow, that SE cam plate is scored worse than I've ever seen.
Old Apr 11, 2019 | 12:18 PM
Garrman's Avatar
Garrman
Trying to learn from this post. Max opined that the cam plate was shot. I am having a bit of trouble seeing the damage. Is it the marks at approximately 2, 3, 4 and 7 o'clock?
Not second guessing anyone but rather increasing my own understanding of what to look for.
Garrman
Old Apr 11, 2019 | 01:15 PM
djl's Avatar
djl
Originally Posted by Garrman
Trying to learn from this post. Max opined that the cam plate was shot. I am having a bit of trouble seeing the damage. Is it the marks at approximately 2, 3, 4 and 7 o'clock? Not second guessing anyone but rather increasing my own understanding of what to look for. Garrman
What Max is referring to is the deep grooving at the face of the camplate that interfaces with the oil pump in the bottom picture. The oil pump fits tight against the plate, no o-ring like the earlier models. Pretty well groove all the way round. If the pump and plate fitted well, you would see some shiny spots but some of the orange coating would remain.
Max Headflow
Garrman
The surface area where the gerotors run is scored.. It should be flat with the rest of the plate. A ton of crap musta gone through the pump.
Old Apr 12, 2019 | 11:04 AM
Garrman's Avatar
Garrman
djl and Max,
Thanks for the clarification. I see what you mean.
I am laughing at myself right now. I was looking so hard at what I thought was the damaged area I never pulled back to see the big picture. It's been a few years since I changed out my cams and plate. I needed to pull out the FSM and do some remedial study.
Thanks again for helping me learn.
Garmann
Old Apr 12, 2019 | 11:16 AM
hrdtail78's Avatar
hrdtail78
Only time I have seen oil pumps break is with excessive crank run out. When ever I see that much metal in an engine. I pull engine apart. The oil filter will bypass and pistons will not live long with a clogged cooling jet. Splash oil in crank case cavity is pretty none existent with case design.
