New Top End
Old Apr 24, 2019 | 12:51 PM
rons73's Avatar
rons73
Default New Top End
Hi just had new SS 110 kit put on, heads done by Dave Mackie compression set 10.7. Im noticing after the bike gets hot it starts feeling sluggish and not as responsive. Coming out first gear is choppy if that would be a correct way to put it. can someone tell me if its running lean or what would be causing this?
Old Apr 24, 2019 | 01:02 PM
djl's Avatar
djl
Check for sumping. Classic symptoms are quick to heat/over heat and sluggish performance. Sumping is caused by improper oil pump alignment and/or poor sealing between the pump "spigot" and the crank case scavenge port. Check by carefully removing the case plug on the right side case bottom to see how much oil comes out. If more than 4-6 ounces, the motor is sumping. The fix is to pull the cam plate, follow the service manual procedure for oil pump alignment (there are alignment pins that some use) and/or replace the seal at the scavenge port. There could be another issue but what is described are classic sumping symptoms and a logical place to start searching for the solution.
Old Apr 24, 2019 | 01:07 PM
rons73's Avatar
rons73
Ok thanks I will check this out. Yea, my buddy was on a 107 stock bike and he took me off the line. I was really pressing on it and bike didnt feel as responsive as I thought it would.
Old Apr 24, 2019 | 01:11 PM
jbarr1's Avatar
jbarr1
Sounds like sumping for sure, but PLEASE get it properly tuned before you trash that new top end.
Old Apr 24, 2019 | 01:20 PM
rons73's Avatar
rons73
it was tuned from the builder with power vision. Thinking of doing another tune with tts
Old Apr 28, 2019 | 07:50 PM
rons73's Avatar
rons73
how easy is it to damage top end? Ive been riding some and just want to make sure i do permanent damage
Old Apr 29, 2019 | 06:46 AM
prodrag1320's Avatar
prodrag1320
pretty easy. overheating is the hardest thing on a new top end,you asked these same questions on the other forum and I suggested there to get it tuned correctly,theres nothing wrong with a PV,no need to go with a TTS.problem is with the guy tuning it
Old Apr 29, 2019 | 07:01 PM
1 2 many's Avatar
1 2 many
Why do people think a base tune is good enough.. complete the package with a dyno session
cthagreekgod
Engine Mechanical Topics
Jul 2, 2019 07:45 AM
Duracell
Jun 24, 2014 10:57 AM
RosevilleCarGuy
Exhaust System Topics
Aug 7, 2013 10:23 PM
jslum
16
Jan 25, 2012 02:21 PM
Rocketman69
EVO
45
May 17, 2010 08:55 PM
