Piston slap question
Old Jun 19, 2019 | 01:12 PM
Iron lHorse's Avatar
Iron lHorse
Default Piston slap question
Could piston slap be silenced by using a heavier oil like straight 50 wt .
Old Jun 19, 2019 | 04:57 PM
bustert's Avatar
bustert
slap is a clearance issue. using heavier oil may/may not add some dampening.
if it is bad, fix it, only leads to worst things.
ole saw dust in the diff'l is just a band-aide.
Old Jun 19, 2019 | 06:11 PM
Iron lHorse
I think I’m going to drain the oil tank and then put just 2 Qts of 50 wt in to do a short sound test . To actually see if it makes a difference .
Old Jun 20, 2019 | 05:55 AM
Mattbastard's Avatar
Mattbastard
How do you know it's piston slap?
Old Jun 20, 2019 | 06:03 AM
prodrag1320's Avatar
prodrag1320
no it wont help,maybe a bit when its cold,but not once the oil gets warm.
BigJess510
May 2, 2013 07:54 AM
tpapa
Oil Archive (no new posts)
Jul 16, 2011 12:31 AM
toycannon
Nov 16, 2009 10:04 PM
Paflyfisher
Mar 22, 2009 11:30 PM
BTROUT
Feb 1, 2006 12:12 AM
