Cam Help
Old Aug 9, 2019 | 10:23 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Reason for the 21 suggestion here, is that it WORKS WELL in an 88", and as we all know how things go....the customer wants more.....then once bored to 98", and say some mild head work.....it still works, only better.
Scott
Old Aug 10, 2019 | 11:47 PM
05flhtbob's Avatar
05flhtbob
I am looking at upgrading a similar 03 FX bike with a carb and it will stay at 88 inches looking at the 21's also..
Old Aug 11, 2019 | 03:17 PM
Dyna Yeti's Avatar
Dyna Yeti
Ok, so I'm seriously considering the Andrews 21s now. Is there any reason why the S&s 509 would be better than the Andrews 21?
Old Aug 13, 2019 | 01:08 PM
dfwhockey17's Avatar
dfwhockey17
Originally Posted by Dyna Yeti
Curious. Why not?
To make them work most of them need a serious bump in compression to get the most out of them. Years ago when I built my 88" into a 117" I used their 594's and knowing what I know now there are cams that would have suit my build much better. We have also used their 574's in a few builds and from a numbers/feel stance there are comparable cams that perform much better...
Old Aug 13, 2019 | 04:36 PM
djl's Avatar
djl
The 509 has an 18* intake close to boost CCP and corrected CR which is why it is a good choice for a Stage 1 88" motor; it was designed for that application.
Old Aug 14, 2019 | 11:53 AM
dfwhockey17
^Word
Old Aug 16, 2019 | 04:35 PM
Dyna Yeti's Avatar
Dyna Yeti
Thanks for the help everyone. I just bought the 509 cams.
Old Aug 17, 2019 | 08:14 AM
Dyna Yeti's Avatar
Dyna Yeti
Can someone provide the 2003 FXDWG stock cam specs?
Old Aug 17, 2019 | 08:54 AM
rigidthumper's Avatar
rigidthumper
Intake -02/38 .473" lift 216° duration
Exhaust 42/-03 .474" lift 219° duration
Old Aug 17, 2019 | 11:49 AM
twincaman's Avatar
twincaman
Default More Torque
My ride is a 2016 Streetglide and it already has V and H dresser duals (cat converter gone) high flow intake and V and H tuner. Any ideas on a cam change that would give a significant boost to low - mid range torque without any top end work?
