2007 softail thought was intake leak but help
Old Aug 11, 2019 | 04:32 PM
1badfxstc's Avatar
1badfxstc
Default 2007 softail thought was intake leak but help
Hello fellas, question. I thought I found a intake leak on my bike. I spray carb cleaner on the back under side of intake gasket and engine would die. Well I replaced intake seals and checked it again and it killed engine. Well to find out it's the head gasket . When I spray the carb cleaner around the head gasket under the intake it kills engine. Is this possible?
Old Aug 11, 2019 | 07:40 PM
Ed Ramberger's Avatar
Ed Ramberger
You're probably bombing it in there like crazy and it's getting sucked in the intake.
Old Aug 11, 2019 | 08:02 PM
Breeze1962's Avatar
Breeze1962
I just went thru this & I agree. It is likely being sucked into the intake. I finally cut some card. Board to block the back side of the breather along with a fan lightly blowing. Then I used propane & couldn't detect a leak anywhere.
cuda67bnl
Exhaust System Topics
Apr 20, 2022 07:32 AM
customsoftail200
Carburetor Related
Apr 15, 2015 08:07 PM
VA_Grumpy_Biker
Jan 22, 2012 12:02 AM
tom73
18
May 14, 2007 09:44 PM
msoucy
Aug 9, 2005 02:32 AM
