hp in a older frame
Old Sep 14, 2019 | 04:55 AM
grbrown's Avatar
grbrown
Thumbs up
Originally Posted by springerboy
i don't know if i would weld across the the tube like that. the way the heat has pushed past the sides of the radius curves leads to more trouble,,,been there and seen it.
That's done by a very competent welder, by the look of it! On my own bike, a 1990 Glide, I swapped for a later s/a, which is much stiffer and doesn't have the weakness that the original had. I haven't suffered any fracture, just wanted improved wheel control, when heavily loaded. I also use a later wheel and rear brake.
Old Sep 14, 2019 | 09:12 AM
Mattbastard's Avatar
Mattbastard
Why thank you Sir. Not my best work but they're plenty strong. I'm self taught anyway so it saves me plenty of money being able to join metal pieces in my garage.
I used a little 85A TIG for them. It's called a Dragster 85, Thermal Arc used to make a few inverter TIG welders, back when Inverter technology was still in its infancy. Now they're a dime a dozen and a hell of a lot cheaper. I still got it, and it's great for light work, less than 1/8" material and exhaust tubing. Nice clean beads. The only problem is there's no high frequency start so you gotta touch the tip to the work to initiate the bead.
I knew about the later swingarm upgrade but I wasn't interested in the whole wheel/axle swap along with it. That and I'd already bought the swingarm bushing upgrade for my model year.
Old Sep 14, 2019 | 09:44 AM
grbrown's Avatar
grbrown
Matt - I tried MIG welding many years ago and quickly realised that I would never make the grade - hence I like to admire someone else's handiwork.
Old Sep 15, 2019 | 03:21 PM
Max Headflow's Avatar
Max Headflow
This stuff is 1018-1020 cold rolled and probably seemed tubing. Should weld just fine. I would not quench in water after welding tho.
Old Sep 15, 2019 | 03:54 PM
Screamin beagle's Avatar
Screamin beagle
Id take care of all that undercut on some of those welds.
Old Sep 16, 2019 | 08:12 AM
Mattbastard
Yea, I probably had the amperage a little high for those beads, and maybe been a bit more generous with the filler. Good thing I don't get paid to weld.
EArthur999
General Topics/Tech Tips
Aug 4, 2020 07:44 AM
eliminator
Nov 16, 2017 02:37 PM
konarider94
Custom Models
May 15, 2013 08:21 AM
joe kustom13
Aug 20, 2012 05:10 PM
GONZEE
Feb 13, 2010 07:40 AM
