Exhaust stud access
my question is this. If I disconnect all the motor mounts, including the rear swingarm to frame mounts, (2000 touring model) can I gain the inch or so needed to drill out the broken stud in-situ?
I realize I will probably have to re-align the motor when done, but that's a relative breeze. I also know that taking a head off isn't that hard, but I dont have a clean/secure area to do it, and I'm not paying 500 bucks again to have a shop do what amounts to a couple hours work, and not have my bike for a week.
You look and the damn thing is right there! But, the down tube is right in the way of getting a good straight shot at the stud. Like you, I looked for every way but the right way to get the stud out. Well, the only way to get to it and do it right is to pull the head.
At this point your only looking for excuses to not do it right. Just find a way and pull the head. You will get the job done right this way and be better off in the long run. Since I had the head off on mine, I went ahead and installed ARP stainless studs on all 4. The rear studs came out ok. Now I can remove all 4 exhaust nuts easily and no more rust!
second, I've already bought the head gaskets, so upon further inspection will most likely go that route. Its tried and true. I'll bring it over to my mother's house with the garage (where most of my tools are anyways) and do it there. It's just more pain in the *** jockeying vehicles back and forth and dealing with the inevitable family politics when **** doesnt go as planned......
there also seems to be some confusion on the Jim's tool as well. It's a simple thing that bolts into the exhaust port with your good stud and has drill bushings to accurately locate a drill for removing the broken stud. Used it on the rear head in situ (much better clearance) when it broke last year, as I figured if two have broken, I better buy the right tool to do this job. It's not cheap, but cheaper than a jacked up head or continuing shop labor. Ironically the stud I replaced is still fine whereas the shop replaced stud broke again......
as for the recurring stud breakage, I have a feeling that the exhaust itself is faulty, as in bent or otherwise not correctly fitting. In addition to the busted studs, it doesn't fit the lower mount at the trans correctly either. Too bad, as it's a factory piece, not aftermarket Chinese cheap **** as you would have expected. It's getting shitcanned when I replace the stud. I'm getting tired of breaking these damn things.
Nomad Max proposed the right solution. Assuming the heads are stock, hunt Ebay for a used head; they are pretty cheap. I just took a quick look and saw two front heads for sale for $135-$140. Just do the R&R job in the parking lot; done in a couple of hours. The OP could have the bike up and running by now with that solution.
1) remove 2 bolts securing left side rear mount cap to frame (no need to remove cap entirely
2) loosen 2 bolts holding right side rear mount cap to frame
these two should allow enough side to side movement to the right to clear the frame rail, as the movement at this fulcrum point isn't extreme. Could probably get away with not even touching these, but the elastomeric bushings are old, why take a chance.
3) remove two bolts from cylinder heads holding upper motor mount in place. no need to adjust dogbone.
4) remove bolt holding lower front dogbone in place and remove throughbolt from front motor mount.
At this point the powertrain assembly is loose in the frame, and should theoretically have enough movement to gain the inch or so needed to clear the right side front frame rail. I would have used wooden blocks to hold the engine stable in that position for the 15 minutes of drilling, cursing and throwing of tools that would then ensue. all the while the bike is securely on my jack to keep the rear wheel from wagging the dog should this goat rope try to be done on the wheels and sidestand. Clearance would be a little tight, but possibly doable in my mind (at the time I came up with this at least)
I know that by nature mechanics are crafty bastards and will come up with alternate ways to get around challenging issues such as the frame rail in the way of the busted stud without resorting to pulling the head and possibly introducing oil leaks or other issues from cracking open the internals for one damn busted stud
I was kind of hoping this was one of those tribal knowledge issues where the accepted procedure is to pull the head (and the job would pay that for flat rate) but you do a couple little tweaks, are done in 1/4 the time with no issues, and on to the next job. I don't understand your concern about "oil leaks and other issues from cracking open the internals". Remove the rocker box covers, rocker support plate and push rods, then the rocker boxes and then the head. If you have the replacement head handy, drop in on with a new gasket and reverse the process taking care not to disturb the cylinder base o-ring; have done it several times. If there was some time between removing and replacing the head, I secure the cylinder to the case with a couple of 1/2" PVC couplings and two head bolts. Have the stud replaced and put the repaired head on Ebay, get your $140 back and you are out a couple of hours of labor, the cost of gaskets and the repair cost and you won't be speaking in tongues and throwing tools around. Like someone earlier posted, there is a reason why your proposed procedure is not common practice.
However, you seem determined to be one of those that likes to swim upstream so I wish you luck with taking on a task that I think is risky. True, mechanics are cratty but they got nothing on Mr. Murphy who shows up at the most inconvenient times.
As I also stated above, Ill take it over to my mothers garage, and do it in there, as the apartment complex has gotten a bit draconian on doing work in the parking lot, and while I can get it done quick anything that obscures the plate is a NO GO, and will be towed in VERY short order, even covers are pretty much banned at this point, due to a couple of ******** using the parking to store their shitboxes. Wife and I are outta here as soon as the lease is up, but not for about another 8 months or so. not gonna pay these ******** for the privledge of moving out early, ill just keep my nose clean until then and keep my truck and bike out of the impound.
im not too hot on using a new(er) head at this point, as the engine has over 100k on it, and I dont want a "fresher" head exposing other issues in the motor. Its lived together this long, ill pull it off and repair the stud. That is what the original plan was already at least
