2002 FLHTC Engine Upgrde
Old Jan 3, 2020 | 07:25 AM
zxport123's Avatar
zxport123
Default 2002 FLHTC Engine Upgrde
Hello forum members:
I currently have a 2002 FLHTC twin cam with a 95 inch motor, and a 5 speed transmission. I am looking to replace the motor with a newer powerplant ( Harley build 124 or 128), would a motor like this built by HD be under warranty in case something breaks? If not, what are my other options for upgrading the motor, budget is not an issue at this time, I would like to go as big as I can.
Old Jan 3, 2020 | 07:53 AM
dracer's Avatar
dracer
building your 95" motor out to a 124 is a great idea. plenty of power right there in the throttle. you will need a new set of flywheels, a big bore cylinder kit and you are on your way. your heads will need some attention to get to the full potential of the 124. there is plenty to discuss when doing this project so feel free to ask all the questions you like. i can help. dsv
Old Jan 3, 2020 | 08:10 AM
zxport123's Avatar
zxport123
Thanks for the info!
Old Jan 3, 2020 | 08:11 AM
djl's Avatar
djl
You can buid a dependable 124" motor on the OEM cases; lot's of help here from Scott/Hillside Cycles or Kirby/VeeTwin Performance. Or S&S offers a low compression 124" motor; sort of a "lazy" 124 but will make 135/135 numbers easy. You will need headwork with the OEM version along with the other associated parts. The S&S motor will come with head but you still need throttle body, air cleaner/filter, etc.
Old Jan 3, 2020 | 03:26 PM
grbrown's Avatar
grbrown
An S&S engine comes with a warranty, check their website. When I installed my S&S engine I also uprated the clutch, replaced the primary chain and comp, as both had a decent mileage and the comp teeth were sharp. The bigger we go, the more we have to upgrade!
cruzmisl
Sep 24, 2023 09:28 AM
SGLife
Engine Mechanical Topics
18
Oct 2, 2019 04:53 PM
4boogie
15
Jun 6, 2014 08:49 AM
flyguy9631
Jul 12, 2013 08:20 PM
98kingflh
Feb 16, 2006 01:57 AM
