Ticking noise what the hell?
Old Feb 25, 2020 | 03:19 PM
1of2's Avatar
1of2
"Moderator"
Mine does it. I figured push rod. Never got around to fixing it but will someday. I'm not worried about it causing a problem.
Old Feb 25, 2020 | 07:10 PM
Lawdawg's Avatar
Lawdawg
Originally Posted by Prodigal_Sun
Failing oil pump? Oil is thinner when it's hot, I don't know if it's enough that it would make a difference... Don't suppose you have an oil pressure gauge you can hook up to it to eliminate it from a possible diagnosis
No, but I did install a high flow oil pump when I did the 107 kit.
Old Feb 25, 2020 | 07:44 PM
TUCCI's Avatar
TUCCI
Originally Posted by Lawdawg
Thank you for putting this in the right topic area, sorry for the hassle.
what is strange is the ticking doesn’t start until the engine is hot and then only at idle until about 1300 rpm and goes away, or I just can’t hear it anymore.
I believe its referred to as lifter bleed-down. I used to experience it on my Road King while running synthetic oil. It finally went away after I stopped using synthetic and went to conventional oil. It took a few hundred miles before it happened. From what I read on the forum this is a common occurrence.
Old Feb 25, 2020 | 08:01 PM
Ed Ramberger's Avatar
Ed Ramberger
I would check that an adjustable pushrod nut didn't loosen up, or they need adjustment. That would account for the noise as the engine grows with heat.
hhkiwi
Dec 29, 2012 10:43 AM
hockey8787
Oct 6, 2008 07:19 AM
Nightster 13
May 22, 2008 08:14 AM
sparky_mo
Jan 6, 2008 05:27 PM
beecha2324
Feb 13, 2006 11:15 PM
