79 shovelhead rod end play
Old Mar 24, 2020 | 12:05 PM
Charlesbreese's Avatar
Charlesbreese
2nd Gear
Default 79 shovelhead rod end play
Do the rods seem like they have too much endplay? Seems a little excessive to me (ignore the background noise, it was pouring yesterday I have a metal roof on my building)
File Type: mov
Old Mar 25, 2020 | 07:49 AM
dracer's Avatar
dracer
they are shot. crank pin probably has a wear groove in it. time to disassemble the lower end and give it a look. most likely will be replacing the rods and do a complete clean out of the oil bag and lines to insure you remove the debris the rods left in the there, you should also replace the pinion bearing and the timken as well, they most likely have metal debris in them. good luck dsv
Old Mar 26, 2020 | 06:30 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
We rebuild/balance crankshaft assemblies constantly.
Happy to help.
Scott
Dragonlady
Engine Mechanical Topics
Apr 26, 2017 05:38 AM
Nugget Shooter
Motorcycles For Sale
Jul 1, 2014 11:38 AM
sqdealgeorge
Shovelhead
Dec 18, 2010 12:04 PM
SportsterBob
Harley Davidson Videos
Dec 10, 2010 07:41 PM
btroy
Shovelhead
Dec 18, 2008 12:18 AM
