Help Crossbones won't run
Old May 29, 2020 | 08:30 PM
tpeskey's Avatar
tpeskey
2nd Gear
Thank you. Plenty of compression it feels like. This may sound somewhat ignorant but when I pull the plug and try to ark it to something Seem like I only am suggessful part of the time. But I think I'm not getting the lug grounded or something. I guess i need to grab my ***** and put a screwdriver in the plug wire. But I am pretty sure it has spark. I Bought fuel rail service kit. Any advice on cleaning the injectors?
Old May 29, 2020 | 08:31 PM
tpeskey's Avatar
tpeskey
2nd Gear
No check engine light. But I do not have a code reader
Old May 29, 2020 | 08:34 PM
tpeskey's Avatar
tpeskey
2nd Gear
What are the odds that I damaged the MAF ( I didnt spray a ton) and will that cause it not to run or not run on 1 cylinder? I figured it would just run rough if MAF was bad
Old May 30, 2020 | 04:47 AM
ScottinAZ's Avatar
ScottinAZ
for just a basic I got **** in the line clean, spray them off with brake clean or other non-residue solvent. Blow the lines out the same way. If anything got past the filters, its easier to just replace the injectors.
allsop
Jun 30, 2015 08:11 PM
Digger1785
May 21, 2013 01:33 PM
priceamp
May 19, 2013 04:56 PM
o3softtail
Jun 23, 2009 12:57 PM
relli
Apr 12, 2009 02:19 PM
