Engine Shutdown
Old Jun 28, 2020 | 12:26 AM
Charlesmi's Avatar
Charlesmi
2nd Gear
Default Engine Shutdown
Harley 2014 Tri-glide will shutdown upon throttle-up after completing a turn or encountering a curve -- Any ideas
Old Jun 28, 2020 | 08:09 AM
grbrown's Avatar
grbrown
Have you changed handlebars recently, or disturbed the handlebar switches? Those are common sources of similar problems.
Old Jun 28, 2020 | 11:55 AM
nevil's Avatar
nevil
Check for codes.
Old Jun 28, 2020 | 12:56 PM
Screamin beagle's Avatar
Screamin beagle
Is there a tilt angle sensor on the tri glide?if so maybe its bad? Just a guess
Old Jun 28, 2020 | 06:51 PM
Charlesmi's Avatar
Charlesmi
2nd Gear
Exclamation Engine shutdown
Not sure of tilt or rollover sensor -- Only E I P appears in window - Yet this is not a code
Old Jun 28, 2020 | 08:16 PM
Ed Ramberger's Avatar
Ed Ramberger
I think you are seeing "tIP" which is what the display says when the sensor thinks the bike has tipped over. The bike has a bank angle sensor, it could be bad, or if you moved it that could be the issue.
Lunchboxx
Engine Mechanical Topics
Mar 2, 2023 10:37 PM
Flatdad
Harley-Davidson Street
16
Sep 10, 2020 04:18 AM
hockey8787
Sep 11, 2011 09:28 PM
