Compression Ratio Calculation
Old Jun 27, 2020 | 09:26 AM
OldMike's Avatar
OldMike
Default Compression Ratio Calculation
I see the M8 128" cylinder kit(s) rated at 11 to 1 compression.
What did I miss with this calculation to get 11.39 to 1?
Used this calculator: https://www.rbracing-rsr.com/compstaticcalc.html
Old Jun 27, 2020 | 10:24 AM
yobtaf103's Avatar
yobtaf103
Mike i use the big boyz calculator, but the factor missing in your calc is the cam, usually input intake valve close value, for true figures & ccp
but inputting what you got i'm getting 11.56 with -1.2 piston
Old Jun 27, 2020 | 10:49 AM
TriGeezer's Avatar
TriGeezer
Wouldn’t there also be some conversion using CCP with ACR disconnected?
For example, the M8 has a nominal CCP spec of 175 Psi. So, if the cylinder is compressing nominal ambient barometric pressure of 14.7 psi, then (175/14.7)= 11.9:1 compression ratio...but...We know that’s not correct....why not?
Old Jun 27, 2020 | 11:14 AM
OldMike's Avatar
OldMike
But as far as the using this calculator I'm correct, right?
I'll check out the Big Boyz one, I'm just doing some comparing now.
Old Jun 27, 2020 | 11:16 AM
OldMike's Avatar
OldMike
I'm just looking at and trying to compare to the advertised compression given for a 128" cylinder kit.
Old Jun 27, 2020 | 11:22 AM
OldMike's Avatar
OldMike
Are you saying if I plugged in a cam calculation my numbers would match the S&S 128" kit at 11:1 comp?
Old Jun 27, 2020 | 12:44 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
The problem with most all of these calculators is they are skipping the area from the top ring to the deck. I also see you place the deck height at 0 which is not typically where any HD engine comes in at. A typical M8 107 is .010 - .014 down and the SE big bore kit typically come in at 0.016 - 0.020 down. You would need to know all this to get a proper compression static ratio. As far as trying to calculate a running compression ratio the calculators get event further off since the valve opening and closing points given on a cam card are not correct. The points on a card are when the lifter has already moved .053" for a twin cam and .050" for a M8! Using the stock HD rocker ratio of 1.65:1 that means the valve is at 0.087 lift for the twincam and 0,083 for the M8. So as you see the cam card doesn't give you where the vale opens or closes at all. At best the various calculators get you in the ball park but none of them are truly correct.
Old Jun 27, 2020 | 12:56 PM
TwiZted Biker's Avatar
TwiZted Biker
See this is the rub, my shovel runs 220-225psi cold per hole but rated compression is 11.7-1.
Old Jun 27, 2020 | 01:01 PM
OldMike's Avatar
OldMike
This clears some things up.
Old Jun 28, 2020 | 11:21 PM
Max Headflow's Avatar
Max Headflow
Because when you compress air quickly it self heats.. See Adiabatic Process.
wessr
Mar 23, 2020 11:16 PM
BobRR
Apr 8, 2019 12:44 PM
scott7d
Engine Mechanical Topics
Aug 25, 2017 02:02 PM
Rustygold
Dyna Parts
Jun 8, 2016 08:43 AM
exactlynowhere
Oct 3, 2015 09:07 PM
