2006 dyna engine heat oil pressure
Old Jul 5, 2020 | 04:31 PM
Morpheus515's Avatar
Morpheus515
Default 2006 dyna engine heat oil pressure
Hi guys, I own a 2006 dyna with 28,000 miles. It is all stock except screamin eagle air cleaner and V & H short shots.I know that harley switched to hydraulic cam chain tensioners beginning in 2007 and all 2006 dynas. However these can still fail at around 50,000 miles, so I figure I'll just replace mine now. While I'm in the cam chest I will also replace the cams, Should I also replace the stock oil pump ? My goal is to reduce engine heat and increase oil pressure,If replacing both, how much lower will engine temp be and how much more psi of oil pressure can I expect ? Thank you. James
Old Jul 5, 2020 | 04:41 PM
djl's Avatar
djl
Replacing the stock oil pump will not increase oil pressure or reduce engine heat. If you wan to reduce oil temps a Jagg 10 row low mount oil cooler will help. With the addition of cams, you should consider a fuel management system and a dyno tune. A proper tune will optimize performance and keep engine heat down.; you will be surprised at the difference a proper tune will make.
Old Jul 5, 2020 | 07:51 PM
Max Headflow's Avatar
Max Headflow
DJL is right on but one additional thing, Dump the smog cam put in a andrews 26 or 48 and have it tuned. Motor will run a bunch cooler with a cam that has some overlap.
Old Jul 6, 2020 | 12:17 PM
eighteight's Avatar
eighteight
In a roller bearing engine, oil VOLUMN is more important than PRESSURE.
That said, plenty of reputable builders state that the stock pump is perfectly fine
Old Jul 18, 2020 | 05:21 PM
Jehu's Avatar
Jehu
Actually, that's true for most engine, but especially roller bearing engines.
Old Jul 18, 2020 | 06:45 PM
Max Headflow
I suspect that more pressure is important for plain bearing crank engines as the tolerances are tighter. You need the pressure the create film strength, where on a roller you just need a dab of oil.
Morpheus515
Engine Mechanical Topics
Mar 31, 2020 05:42 PM
Morpheus515
Jan 29, 2020 09:22 AM
evolyn
Mar 26, 2019 05:32 AM
dynarule
Oil Archive (no new posts)
11
Oct 2, 2009 05:13 PM
rleggs
Jun 10, 2007 10:58 AM
