Cylinder base gasket
Old Jul 16, 2020 | 08:34 AM
Adam76's Avatar
Adam76
Originally Posted by Hillsidecycle.com
We glass bead that paper gasket off, then into the lathe fixture to establish flat/perpendicular to the bore C/L.
.005" is a typical cut.
Scott
Originally Posted by prodrag1320
if it is the cometic steel gasket,it should come right off,if its a paper gasket,bead blast it off (or machine it like stated earlier)
Thanks Scott and Kirby,
I'm thinking it may be the factory gasket because there were signs of light brown silicon used the inside of the engine case and even a bit stuck to one of the rods. Did they do that at the factory?
Anyways, I've taken it to the machine shop to be done. They are blasting it off.
Cheers.
** Also want to pick your very knowledge brains on how to factor in new base gasket thickness when calculating zero deck height. Do I place the new base gasket in place, torque cylinder down fully? To check deck height? Or do I use a generalised assumption of how thick or thin the gasket will be once compressed?
Hope that makes sense.
Old Jul 16, 2020 | 08:35 AM
Max Headflow's Avatar
Max Headflow
Yeah, It may be stainless steel and not aluminum. I generally set up without the base gasket then gust add it as most cometics have embossed sections that crush. Some have gotten away with reusing crushed gaskets but I've had leaks from even good cometic gaskets.
Old Jul 16, 2020 | 08:38 AM
Adam76's Avatar
Adam76
thanks max, so generally how thick would you say a used / compressed base Cometic gasket would be?
Old Jul 16, 2020 | 09:09 AM
Max Headflow
Cometic make all kinds of thickness of base gaskets. As to to how much they compress, I'd say only 1 or 2 thou from new measured at the non embossed(thinnest) part.
Old Jul 16, 2020 | 03:47 PM
60Gunner's Avatar
60Gunner
I've reused the cometic mls head and base gaskets 3 times and never had a leak.
Old Jul 17, 2020 | 05:55 AM
prodrag1320's Avatar
prodrag1320
if your going back to the OEM gaskets,you should have measured for deck hieght before having the gasket removed
Old Jul 17, 2020 | 06:27 AM
Adam76's Avatar
Adam76
no, not going back to oem - using a new Cometic base gasket (see a few posts back). Just wondering how to calculate an accurate deck height without ruining the new gasket?
Thanks.
Old Jul 17, 2020 | 06:29 AM
Adam76's Avatar
Adam76
ok thanks, that sounds easy enough.
Old Aug 13, 2020 | 07:42 AM
Adam76's Avatar
Adam76
Scott
Thanks Scott, now that I've cut .005" of the bases -- I want to install cylinders to check piston deck height with new pistons..... How do I do this without crushing the new Cometic .020" base gaskets when torquing down the cylinders?
Thanks for your advice.
Old Aug 13, 2020 | 04:44 PM
60Gunner's Avatar
60Gunner
Dont worry about crushing them. You can reuse them repeatedly after til the black starts to wear off.
Made me cringe reading how some removed that paper gasket.
jayxl1200
May 25, 2020 01:39 PM
jmd897
Engine Mechanical Topics
Sep 26, 2019 11:56 AM
MuddBugg
Aug 5, 2013 10:05 PM
WARG
Mar 24, 2008 11:57 PM
Naz_Man
Jul 18, 2006 01:42 AM
