Head Gasket Replacement
Old May 25, 2020 | 09:30 AM
jayxl1200's Avatar
jayxl1200
Stage I
Default Head Gasket Replacement
Hey all so im currently in the process of doing a headgasket my question is that since i havnt pulled the cylinder would my base gasket still be good to run or is it junk now that theres no pressure. id rather not pull the cylinder if i dont have too gasket has never leaked on me. thanks
Old May 25, 2020 | 09:43 AM
Bass Player's Avatar
Bass Player
You don't re-use any gaskets. Some do outer primary, but that's it. Results may vary. Buy good not cheap crap gaskets. The cheap will become the expensive!
Old May 25, 2020 | 10:50 AM
John Harper's Avatar
John Harper
Well, I'd suspect you probably should change it, even if it's a PITA. Otherwise, you just know if you don't it will start leaking. My front one has seeped a bit for years, nothing a quick wipe with a rag won't take care of. If I ever decided to change it, might as well toss on a 1275 kit since the jugs are off already. I'd wait for a few more opinions for sure.
John
Old May 25, 2020 | 11:13 AM
apache snow's Avatar
apache snow
Ive pulled the heads several times with out replacing the base gaskets with no issues. Think how many times hammer pulls and replaces the heads while testing without changing the base gaskets. They even re use the head gaskets till the finish starts to wear. But there are some that are **** and will change every thing if they are going in. Do what you feel is best for you.
Old May 25, 2020 | 12:00 PM
Madnss's Avatar
Madnss
I reuse cometic base, head and rocker gaskets all of the time.
Old May 25, 2020 | 12:07 PM
ahern25's Avatar
ahern25
I would say if you feel that the base gasket has broken its seal from the cylinder in the process of what you are doing then yes. If you dont think you moved it enough to break the seal it has made then you should be good to go. One trick is small PVC pipe sliped over the two cylinder studs a washer and nut to keep down ward pressure so as to not break the seal.
Old May 25, 2020 | 01:39 PM
BrandonSmith's Avatar
BrandonSmith
Active Streak: 30 Days
I had to head gaskets replaced under warranty, in the dealership replaced the base gaskets as well, I don’t know if that tells you anything, but if it were me I would change them as well
Road Star
May 15, 2017 07:05 PM
drhooligan
Engine Mechanical Topics
Nov 11, 2016 05:47 AM
JimmieJack
Exhaust System Topics
Feb 7, 2011 08:24 PM
stlboarder
Dec 23, 2010 10:46 PM
rivercityslim
EVO
Nov 16, 2009 02:50 PM
