Cam upgrade suggestions
Old Aug 10, 2020 | 04:24 PM
bigdog1949's Avatar
bigdog1949
Default Cam upgrade suggestions
I have an 12 ,103 streetglide would like to put in some cams,chain drive,all around cam,low end torque ,any suggestions ??,have Open Exh and breather SE .
Old Aug 10, 2020 | 04:31 PM
00BUCKSHOT's Avatar
00BUCKSHOT
SE255 is a good bolt in cam. S&S 510 won't make quite as much hp as the 255 but is another great bolt in cam. bolt in means no head work stock valve springs will work
can't forget about the Andrews 26 grind
Old Aug 10, 2020 | 05:20 PM
djl's Avatar
djl
Andrews 48 would be a good choice. A lot like the SE255 with good bottom but will carry out farther than the 255 and make more HP. If just looking for stump pulling TQ, the 255 will do that but falls on it's face about 4000rpms.
Old Aug 10, 2020 | 05:27 PM
00BUCKSHOT's Avatar
00BUCKSHOT
i pulled my 255's out not long after install and built it right, head work, 259e cams, 10:5-1 pistons. really woke my engine up
Old Aug 10, 2020 | 05:33 PM
Paul-S's Avatar
Paul-S
https://university.fuelmotousa.com/a...haft-shootout/ Here's a few to look at.
Old Aug 10, 2020 | 09:08 PM
Harley1004's Avatar
Harley1004
Andrews 48
Old Aug 11, 2020 | 03:42 AM
60Gunner's Avatar
60Gunner
Might as well throw the S&S 583s in the mix. They'll run out a little better than the 255s too.
​​​​​​That 259E has never been accused of being a stump puller but in that torque range there's bolt ins like the S&S 570 and TW555 or Andrews 57s that would do better and at 10.5:1 there's a shitload better choices. In fact at 10.1, 10.2 those 570s or 555s or 57s would do well in this case for a broader torque curve and little less stump pulling.
For stump pulling bolt ins tho, he's got some good choices above.
Old Aug 11, 2020 | 06:02 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
We would suggest the 48's as well.
If wanting more, then we'd re-work the heads and use a different cam.
Scott
Old Aug 11, 2020 | 06:14 AM
prodrag1320's Avatar
prodrag1320
look at the S&S 583 cams,
Old Aug 11, 2020 | 05:53 PM
bigdog1949's Avatar
bigdog1949
I really don’t want to get into the head work Scott but what about the 77 cams I have V&H powerduels ,just lookin for some more *** out off this 103 !
