2002 TC88 - Camchain needed?
My buddies Road King,the shoe on the left came apart and made a squeal noise,then he took it to the dealer 1600 buck later had the screaming eagle hydraulic tensioner upgrade.
I'm curious what your crank run out is.
getting the oil pan is very awkward, particularly without a bike lift.... just laid on garage floor lol. Even harder though, is scraping the OLD oil pan gasket off down there! lol.
For reference - i found taking off the rear brake push bar (dont know proper name!) made it easier to reach a couple of the hard to reach screws.
I still need to flush the oil lines if i can, too.
I've ordered a DTI which should be here this weekend, and i'll check the crankshaft runout for peace of mind. I've visually inspected the pushrods (rolled them on a flat surface) and they dont appear to be bent either.
Fingers crossed!!
The Cams... at this point, anyway... dont look as bad as they could do!
cam case cleaned out.... just waiting on DTI to arrive to double check crankshaft runout.
Oil pan much cleaner now than it was!
My DTI arrived at the weekend, so i could check Crankshaft runout. I clocked it at the very end of the shaft (most outward point without flats) and quite impressed that it was only 0.0004... i was expecting worse!
I've removed the inner cam bearings now, but disappointed to see that the cam bearings included in the gasket kit are the INA ones! so i've discarded them, and ordered Torrington ones. In the meantime, ive fitted the external bearings into the new cam plate, along with the existing Cams.
If anyone else is following this thread with the intention to do this - the SE Hybrid kit Instructions say you need to purchase the Drive Gear Retention Kit separately - this is NOT the case now, as my Hybrid kit has these fixings included inside!
