Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Thinking of some winter projects.
I am considerng haveing headwork done and cams. What shop do you guys recommend for the headwork and what cams would go good with it. Also woud using a thinner headgasket rais compression a litle? and is hat something should do. Bike is 2015 Ultra Limited Twin ooled 103. Gonna keep stok bore or now.
Thanks
Jeff
Have a long conversation with your tuner. They will ask you many questions that will allow them to create the build that best suits your riding style and budget.
