M8 Engine Defect From Factory
Old Nov 27, 2020 | 07:24 AM
2013_FLHTK's Avatar
2013_FLHTK
Default M8 Engine Defect From Factory
Has anyone watched what Kevin Baxter posted on his YouTube page regarding a 2017 M8 factory defect?
I enjoyed watching but felt extremely bad for the owner and what he had to endure.
Part 1
Part 2
Part 3
Old Nov 27, 2020 | 08:12 AM
Mattbastard's Avatar
Mattbastard
Cliffnotes?
Ain't got time for dat!
Old Nov 27, 2020 | 08:40 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Nope.
Old Nov 27, 2020 | 08:50 AM
2013_FLHTK's Avatar
2013_FLHTK
Originally Posted by Mattbastard
Cliffnotes?
What I got from this is do not let the dealer tell you everything is alright when you know it's not. The other amazing thing is that the engine was still running after years of metal flowing or should I say stoping the lubrication.
Old Nov 27, 2020 | 08:54 AM
Max Headflow's Avatar
Max Headflow
If you run it at 2x video speed and use the L key to step forward, you can get through it pretty fast. Really only need to view the last video.
It looks like the motor had a bunch of machining swarf stuff in the pushrod area. Not sure how it got there but it's likely left over from machining the cases. I would guess that somehow the swarf got packed into a passage and missed during assembly. It slowly worked it's way out into the pushrod area. The only other possible reason might be that some dumped the swarf into the tappet cover during assembly.
Old Nov 27, 2020 | 09:52 AM
2013_FLHTK's Avatar
2013_FLHTK
Never knew about the "L" key. Thanks for the tip.
Old Nov 27, 2020 | 09:55 AM
Max Headflow
One more J will back the video up.
https://support.google.com/youtube/answer/7631406?hl=en
Flatdad
Harley-Davidson Street
16
Sep 10, 2020 04:18 AM
Mugsy666
May 14, 2013 03:11 PM
HDF Tech
Engine Mechanical Topics
Oct 22, 2005 12:00 PM
HDF Tech
Aug 11, 2005 04:06 PM
