Release Valves?
Old Feb 8, 2021 | 08:29 AM
Mattbastard's Avatar
Mattbastard
Originally Posted by Tony Tharp
The tech doing the work doesn't trust 'em. He has used 'em with no problems reported back, but he said he has heard of them failing.
Are you the customer? Tell your "builder" to stow his rumor mill and use the EZ cams. OEM's have been using that technology (some even have S&S make their cams) for years now with zero issues.
Old Feb 8, 2021 | 09:51 AM
smitty901's Avatar
smitty901
Forget the ez cam . 10.5:1 compression yes you need compression release. If you take the short cut you will pay for the mistake latter.
Look at it this way why did HD put Compression releases on as standard equipment when the raised compression to 10:1.
Old Feb 8, 2021 | 11:47 AM
60Gunner's Avatar
60Gunner
Not sure what the MCRs are costing you or what you paid for the standard version cams but you would've spent roughly another $80 on the easy starts. I paid $270ish for my standard 570s and the easy starts would've been $350ish.
Probably close to a wash?
Old Feb 8, 2021 | 11:53 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Pretty sure the average price to machine in a set of manual compression releases are right around $150. The nice thing about doing them is that you don't have to take the tanks or anything off to get to your ACR's.. They're right there in the wide open.. So when they do go bad it's a 5-minute fix... To each their own.....
Old Feb 8, 2021 | 01:51 PM
Campy Roadie's Avatar
Campy Roadie
The advantage of the EZ starts over MCRs is they are always ready for hot starts (say for instance a stall in traffic) as opposed to having to reach down and open MCRs. I have EZ start gear drives in my Road King and am very pleased with them. Mechanically, I'd say an ACR or MCR would fail before the S&S EZ, it's not new technology.
Old Feb 8, 2021 | 05:31 PM
Mattbastard
Yup. Think of the cost to have your heads machined, buying the MCR's, and the bitch about having to reach down every time you wanna crank your bike over.
Now think of how much the EZ cams are over the normal ones.
Are those two values the same? Doubt it...
Old Feb 8, 2021 | 05:35 PM
eighteight's Avatar
eighteight
Although I have manuals I will point out that my 1970 Cub Cadet with a Koehler 301 single had ACR with a centrifugal valve lifter device!!😃
And it wasn’t a new idea then!😃
Old Feb 8, 2021 | 05:38 PM
eighteight's Avatar
eighteight
Fwiw that is what I paid while having heads ported & refreshed
ymmv
Old Feb 8, 2021 | 05:52 PM
Clammy's Avatar
Clammy
Enh... it's no big deal. It becomes very routine, like turning the ignition switch on before hitting the start button. I've never bitched about having to press my MCRs. Not meant as a comment on the EZ start cams, Just an observation.
Cheers!
Old Feb 8, 2021 | 08:32 PM
98hotrodfatboy
ymmv
Yes that would be correct... He is tearing down the motor anyways...
