Release Valves?
Old Feb 9, 2021 | 08:38 AM
Mattbastard's Avatar
Mattbastard
One other slight against the MCR's, when I had them on my 88CI Sportster after the first revolution of the crankshaft they would slam shut because of the higher compression. No fire, just enough compression to make them think a spark fired. Yes the crank was now spinning under its own inertia but cranking was very labored.
One pro to the MCR's, if they fail they're very easy to change out.
In that regard, how often do you hear about MCR's or EZ cams failing?
Old Feb 9, 2021 | 09:01 AM
98hotrodfatboy's Avatar
98hotrodfatboy
l will say that I had a set of MCR's that did give me issues at times where I had to use Kroil to clean and lube it because the carbon build up would make it a little difficult at times to depress.. They weren't from one of the normal porter's here..
Old Feb 9, 2021 | 09:19 AM
Bingee's Avatar
Bingee
Originally Posted by Tony Tharp
The tech doing the work doesn't trust 'em. He has used 'em with no problems reported back, but he said he has heard of them failing.
You will always be better off relying on hard documented information when deciding the reliability of what you add to your bike. That goes for anything actually. So ignore opinions like "...has heard of them failing", without a single incident to back it up. You'll be far better off doing your own factual research and relying on opinions of posters who have a proven record of reliability. I believe djl is one of those. Ride safe.
rons73
Apr 4, 2019 03:28 PM
mrsnipy
Mar 8, 2019 10:45 AM
Big Money
Engine Mechanical Topics
19
Jun 20, 2015 06:37 AM
morespeed
Exhaust System Topics
Nov 15, 2011 02:00 PM
pearlr
Sep 12, 2010 07:15 PM
