Panhead cases question
Old Apr 10, 2021 | 08:44 AM
Parts.69's Avatar
Parts.69
Stage IV
Default Panhead cases question
So I have a set of right side 55 cases and was gonna buy a repop left side 55 case. I feel like I hear a lot that it's hard to make a crank unless the cases exactly match. How hard would it actually be? Is this a legit thing or is it just my engine builder not wanting to do with it? Thanks in advance for any answers
Old Apr 10, 2021 | 10:22 AM
pgreer's Avatar
pgreer
I think it largely depends on the quality of the reproduction case and how well it lines up with the right side. That's one reason the case halves are matched from the factory.
The 1955 big twin uses timken bearings (I believe it was the first year for that), but the right side uses flat roller bearings. It is critical that the left and right bearing races are aligned, so if the right case bearing race is not properly aligned when the case half was cast, it could be problematic when setting up bearing clearances and end play. That being said, it's been done more than a fair amount, so it can be done.
The right case bearing race is lapped to size using a lapping tool that works off the alignment form the left case to maintain the alignment between the bearing races.
Perhaps the shop you are working with has not done a lot of this and is not comfortable with the process. A lot of shops seem to not want to work on the older engines.
Paul
Old Apr 10, 2021 | 05:05 PM
wfolarry's Avatar
wfolarry
The cases never match. Not only do you have to do the line bore but also the gasket surface & the motor mounts. Everything needs to be checked. It can be a PITA. The last set I did was an Evo. Couldn't believe how far off they were. Took more than a hone to get those bearings in alignment.
If new cases are available but them. It's better to start with a matched set.
Old Apr 11, 2021 | 08:36 AM
bustert's Avatar
bustert
super +1
machine shop charges will exceed what you are expecting. yes, with $$$$$$ it can be done.
i have found that hd shop will not touch even newer models. they will do minor things like boring and such but a case up not so much. they would prefer you to seek an independent shop. i had a friend with a 1975 fx frame up restoration and he had night mares with it and the shop had to completely redo all of their work, they didn't even test run it. he brought it to sturgis to sell and the engine locked up. choose well, choose well
panz4ever
Shovelhead
Jun 19, 2019 01:33 AM
sixguns
Milwaukee Eight (M8)
Jan 13, 2019 10:20 AM
richard567
EVO
Jun 5, 2017 04:51 PM
buckfw
Mar 11, 2015 07:08 AM
skully1200
Feb 13, 2012 09:09 AM
