TC88 Winter build.
Old May 8, 2021 | 04:05 PM
Mark Pisani's Avatar
Mark Pisani
Default TC88 Winter build.
Engine rebuild newbie here......
I did some work to my 2004 FXDI over the winter. First time ever with a Harley. Got a set of 95” cylinders and pistons from a friend. Also a set of newer take off 103” heads. Changed to 510G gear driven cams (runout was good at 2.5 thousands). All parts were used but good shape. New lifters and new pushrods (adjustable).
Engine runs great. Got a PV and with a few tweaks from fuel moto she rips. Sounds good too. I’ve had a stethoscope on it a few times and all sounds good to my amateur ear. Plugs have been checked regularly in the 1000 kms or so since the rebuild and only concern is the ring has a bit of an black oily look to it. Not too wet but not carbony like it’s supposed to be.
Anyway I did the 500 mile oil change just recently and there was some metallic ‘threads’ in the oil. The magnet on the drain plug had normal looking wear slug. The metallic threads do not appear to be magnetic. I was concerned so put another 200 miles on it and changed it again and they are still showing up.
Don’t know if I should tear it apart and see what’s going on or if this is somewhat ‘normal’ and let her run for a bit more. I really just don’t want anything catastrophic to crater my engine.
Old May 9, 2021 | 10:05 AM
djl's Avatar
djl
Compression and leak down testing should give a hint and the usual starting point for motor diagnostics. You might consider getting a oil sample collection kit from Blackstone and have the oil analyzed; Blackstone will send the kit free and the analysis runs about $25 IIRC.
Stiletto15
Mar 30, 2013 04:19 PM
producer
Oct 7, 2012 09:01 AM
SCHOONER
EVO
34
Apr 28, 2012 04:48 AM
Ernie 06
Feb 19, 2010 03:50 AM
driftbuster2
Exhaust System Topics
Nov 19, 2007 02:17 PM
