Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
If using the 103” heads to big bore a 96” to a 107” can the stock ACR’s be removed and manual ones installed?
the 96” wiring harness does not accommodate the releases .
I swapped a 96 to a 103HO on my 07 flhtc and it cost me $200 I think to get the dealer to install the wires and flash the ECM to make the 103 from a 2014 Streetglide.to work properly.
Yes they make plugs for the ACR's & MCR can be machined in,but I would get the harness & use the ACR's
That is what I did to the heads when I built a 98" motor for my '05FXSTD. Personal choice, I have always used manuals, used to them and did not want to change.
