No ignition , nothing come on
Old Jul 16, 2021 | 07:52 AM
uride2's Avatar
uride2
Default No ignition , nothing come on
What do I check first ?
Harvey
Old Jul 16, 2021 | 07:54 AM
Ron750's Avatar
Ron750
Kill switch. Battery. We are going to need more details after that. Year, model, modifications, any preceding symptoms, age of battery.
Old Jul 16, 2021 | 10:35 AM
twincam10353's Avatar
twincam10353
Well if "nothing comes on" we know we have some form of an electrical issue right away.
Old Jul 16, 2021 | 10:54 AM
uride2's Avatar
uride2
97 Heritage tested Battery .it`s good . mostly stock with 274,000 miles
Old Jul 16, 2021 | 01:30 PM
uride2's Avatar
uride2
how do i check kill switch
Old Jul 16, 2021 | 01:31 PM
uride2's Avatar
uride2
Old Jul 16, 2021 | 02:27 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
How did you determine that the battery is good?
How old is the battery?
The battery must be fully charged, and then load tested.
If you did not have the battery load tested then you haven`t checked the battery...
This bike has a very simple electrical system, it will be easy to find the problem, you just go one step at a time.
But one thing is for sure...
The Kill switch is not the problem.
Old Jul 16, 2021 | 03:00 PM
Max Headflow's Avatar
Max Headflow
If the battery is charged and everything is hooked up right, it's probably the ignition switch. They get corroded, then overheat and melt.
Old Jul 17, 2021 | 05:25 AM
uride2's Avatar
uride2
Took battery to where i bought it they check said it was good
Old Jul 17, 2021 | 05:26 AM
uride2's Avatar
uride2
Thanks I`ll check it
